  • SN95 4.6L Mustang Tech
quick "Overheating" question
  • Thread starter Thread starter 96s281
  • Start date Start date Jun 8, 2005
9
96s281
110
  • Jun 8, 2005
I did a couple of different searches but most of the overheating questions weren't in the 4.6 section, so I figured I'd give it a shot here...
Car temp radically increases when idling (i.e. going from the "R" to the "L" on the NORMAL gauge when just sitting at a red light for more than 30 seconds). I don't believe my fan is coming on at all unless I put my a/c on. When I do put it on, the temp gradually goes back to the "R" and stays that way until the next prolonged stop.
As long as the a/c is on, the temp gauge is fine, even at prolonged stops. I still have my stock thermometer, which is crap from what I understand. Any ideas?
Thanks in advance!!
Jinx
I like cats, cats like me. Cats and I fully agree.
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Jun 8, 2005
  • Jun 8, 2005
A simple way to rule out the fan, bring the car up to temp, while parked somewhere, pop the hood and watch to see if the fan comes on. If it doesn't I'd be suspect of a bad fuse or electrical connection. The only other thing I could think of would be a faulty temperature sending unit. See if you can pull a code for it (it may or may not trigger the service engine light).
Good luck
9
96s281
110
  • Jun 8, 2005
Good luck
Thanks for the quick reply Jinx....I took it to my mechanic last year when it was showing the same symptoms and he swore nothing was wrong and the fan came on when it should've. Since then I got a new radiator and water pump, so I'm thinking I can rule those out, but who knows.
RandyStinchcomb
1,159
Randallstown, Md
Jun 8, 2005
  • Jun 8, 2005
one thing to know is 1996 had a TSB for overheating issues and Im not saying togo out and spend $1k on the kit but 1 thing Ford did in 1997 and 1998 was to delete the honeycomb grill behind the pony emblem to help promote better air flow to the rad. next step would to put a larger radiator in place of the stocker, I did this on my 1996 Gt a few years ago and no more problems but mines not a "street car" anymore
warment
339
Spotsylvania, VA
Jun 8, 2005
  • Jun 8, 2005
I'll tell you exactly what your problem is...you have a faulty Engine Coolant Temperature (ECT) Sensor. The fan is not coming on when it is supposed to come on. As the water temp rises, this sensor is supposed to have a lower resistance. You can check the resistance with a volt/ohm meter.
The fan come on by default when the AC is turned on, so leave the AC on until you test and replace this sensor. A new sensor should be less than $20.
Bill
slvrgt
40
  • Jun 8, 2005
get a 180* thermostat
9
96s281
110
  • Jun 8, 2005
Thanks for all the replies fellas. I think I'm gonna let it run in the driveway until it gets hot to see if the fan comes on, and then take it from there. Thanks again for the help
MyEarsHurt
918
  • Jun 8, 2005
Another thing, just to help the situation, clean out your radiator really good. My buddy's car was running really hot and he took it to the car wash and powersprayed the hell out of his radiator. It was pretty dirty...anyway his car is running fine now. Worth a shot if nothing else works...
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Jun 8, 2005
  • Jun 8, 2005
Try a product such as Water Wetter also. It helped mine somewhat in the operating temperature range. As far as idle you probably have a fan issue.
saleen556
387
Hillsboro,OR
Jun 8, 2005
#10
  • Jun 8, 2005
  • #10
I agree with WARMENT.It sounds like the ect.Cheap fix.
9
96s281
110
#11
  • Jun 8, 2005
  • #11
Well, I let the car run when I got home and the fan did come on right as the gauge went to the "A", so it did take a while. I think I might get that ECT anyway if it's only a couple bucks.
Is it normal for the fan to come on so late?
Wikkdgt
445
Cincinnati, OH
Jun 8, 2005
#12
  • Jun 8, 2005
  • #12
Mine was overheating at stops too. Didn't know what the hell the problem was. Fan wasn't coming on anymore. Took in to my buddies dealership and found out that the connector that plugs into the back of the fan had somehow come loose. As soon as he plugged it back in, the fan kicked on. Check that first.
9
96s281
110
#13
  • Jun 9, 2005
  • #13
What exactly does getting a 180* thermostat do? Does it trick the engine into thinking it's running cooler than it actually is? How does that work?
9646gt
595
Holloman AFB,NM
Jun 9, 2005
#14
  • Jun 9, 2005
  • #14
a 180 thermostat will actually open up at 180* instead of 190* wich will let coolant into the motor eariler
9
96s281
110
#15
  • Jun 9, 2005
  • #15
Ahhh, thanks!!!
warment
339
Spotsylvania, VA
Jun 15, 2005
#16
  • Jun 15, 2005
  • #16
How many miles has it been since you flushed your radiator? I am in the process of installing a supercharger and drained mine at 76k...my fluid was pretty nasty. You might want to consider a flush as well.
Bill
C
Fuse help please. 73 Mach 1
  • Curtis Harper
  • Oct 19, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 28, 2026
Curtis Harper
C
G
2016 GT, Cold Air/Tune Trouble (overheating) . Advice/Help Please!
  • GLStang
  • Sep 6, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Sep 6, 2025
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
Progress Thread Sask84gt's 84 GT - Questions and Progress Thread
  • Sask84gt
  • Oct 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
Sask84gt
O
2001 mustang gt overheating
  • orinsmiley11
  • Jul 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 17, 2025
