Quick Question! about 351w swap
asking this for a friend...
is there a difference between the 94-95 wiring harness and the 89-93 mass air wiring harnesses because im doing a 351w swap and i have a distributor from a 94-95 f150 (forget which one) and my harness doesn't have what plugs into the distributor. so what im asking is can a 94-95 f150 distributor be used on a 5.0 wiring harness. let me know thanks :nice:
ttt... you mean you dont think the f150 distributor would be compatible? because it is a mustang harness im using not a f150, so like i said, need to know whether a 94-95 f150 distributor could be used on a 5.0 mustang mass air harness. otherwise what distributor could i use for this 351w that would be compatible? let me know thanks
If I remember right, the f-series had the TFI module mounted external to the distributor so no the dist. would not plug into the mustang harness.
MSD has a distributor for a 5.8 EFI swap.
