  • SN95 4.6L Mustang Tech
quick question about shift kit..
  • Thread starter Thread starter tmkester
  • Start date Start date Mar 29, 2012
tmkester
39
Pennsylvania
Mar 29, 2012
  • Mar 29, 2012
i have to pull my trans out eventually to fix a rear main seal leak and while the trans is out i was looking at putting a shift kit in it, seems cheap and easy. With that being said, what kind of difference does a shift kit make, would it be worth it.. and it also says it prolongs the life of the trans how true is that? thank you
M
Moon
190
Close to Chicago
Mar 30, 2012
  • Mar 30, 2012
From what I've read, it prolongs the life by shortening the shift time (in which the trans is essentially in two gears at the same time, which is bad). Having said that, it should be a little quicker and/or more fun to drive. I've read that shift kits are installed where the valve body is, which can be accessed by jacking the car up. Lastly, most programmers nowadays should be able to change shift points in the computer, so you may not need a shift kit in the first case.
Either way, I plan on picking up a B&M shift kit as soon as I'm not a broke ass.
3,287
24
69
Broke
Mar 30, 2012
  • Mar 30, 2012
I have a transgo. It made the shifts much quicker, more solid. These days tuners do a good job by adjusting the shift pressure. If you arent happy with what you got from the tuner, then do a shift kit too.
The biggest improvement to the auto trans performance is the improved shift pattern in the SF3 tune. The biggest improvement to the trans longevity is a trans cooler.
tmkester
39
Pennsylvania
Mar 30, 2012
  • Mar 30, 2012
im a broke ass too so im just looking for things that will help that are on the cheap side, i already have a tuner so ill just try to get a tune with better shift points.
san~man
O-G
A little grass shack on a big lava rock
Mar 30, 2012
  • Mar 30, 2012
Jmod
/thread
nyuk98gt
1,427
Chesterfield, MO
Mar 31, 2012
  • Mar 31, 2012
tmkester:
To add a little to the excellent advice given by "san-man", please go to TCCoA.com/Tech Articles/Transmissions and read "Transmissions 101" by Jerry Wroblewski (former Ford Transmission Engineer). If you read the "Shift Kits" articles, please note that they are a bit out of date. Also, read the two how-to articles by "A-Train". Learn those three documents well and then do the work.
The J-mod is not 100% free but it won't cost you much - you just need fresh ATF, a couple of gaskets, maybe a couple of accumulators and springs (depending upon the year of your car), and some patience.
Now, go git 'er done.
Chris
usaf_branham
927
134
84
Boston
Mar 31, 2012
  • Mar 31, 2012
why install a shift kit when you can j-mod it?
M
Mary brown
Banned
Feb 7, 2012
17
  • Mar 31, 2012
That is a great site! I saw the information is very usefule!
D
Deleted member 38176
Apr 1, 2012
  • Apr 1, 2012
Shift kits are a thing of the past. Modern handheld tuners can do the same thing for free.
nyuk98gt
1,427
Chesterfield, MO
Apr 1, 2012
#10
  • Apr 1, 2012
  • #10
Nightfire:
Handheld tuners do not address hydraulic improvements. The (centrifugal) pump only puts out so much flow for a given pressure so if the pressure is increased then there is less flow. This will improve flow to one area but there is less oil flow to another part of the transmssion. If, however, the holes in the separator plate are opened up then the pressure drop is reduced (so the discharge pressure of the pump does not need to be increased) and more fluid can flow to all parts. Improving the hydraulics makes the shifts quicker (faster) and reduces fheat build-up due to friction so the clutches last longer. So, imho, it is premature to say that shift kits are no longer needed. No flame intended, just presenting an argument why improving hydraulics needs to be done in parallel with tuning if one is to see the maximum benefits.
Chris
Reactions: sneaky98gt
tmkester
39
Pennsylvania
Apr 1, 2012
#11
  • Apr 1, 2012
  • #11
thanks for all that info man, very helpful
nyuk98gt
1,427
Chesterfield, MO
Apr 1, 2012
#12
  • Apr 1, 2012
  • #12
tmkester:
You're welcome. I tend to get a little nerderiffic when typing up stuff about automatics.
Now, go read Transmissions 101 and the A-Train how-to's and then report back with your plans.
Chris
bmanrocks01
24
Lebanon, Missouri
Apr 1, 2012
#13
  • Apr 1, 2012
  • #13
I just got my shift kit in the mail from american muscle. i think it was 80 bucks? i have a programmer so i will prob run without it first, then see if there is a change.
tmkester
39
Pennsylvania
Apr 3, 2012
#14
  • Apr 3, 2012
  • #14
i think im going to just call bama and get a new tune with some firmer shift points, then by the time i pull out the trans i will have enough $$ to blow on the shift kit, whats the worst that can happen right? and bmanrocks01, reply if you can about how it does with the tune and shift kit.... im about to just switch it to a 5spd
sneaky98gt
2,387
144
114
NC State University
Apr 3, 2012
#15
  • Apr 3, 2012
  • #15
In the words of San-Man
"J-mod.
</thread>"
san~man
O-G
Apr 4, 2012
#16
  • Apr 4, 2012
  • #16
With the Jmod and the PI torque converter, the shifts were smoother, faster and harder (when needed) than stock. Driveability improved greatly over stock, and sometimes you couldn't even tell it was shifting (low speeds).
However, when you mashed the gas, shifts were hard (in a good way) and much faster. I could chirp the 2/3 shift if I felt like it.
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Yesterday at 4:40 PM
manicmechanic007
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
