quick question about the AOD
  • Thread starter Thread starter chobracobra
  • Start date Start date Jun 15, 2006
chobracobra
175
jersey shore
Jun 15, 2006
  • Jun 15, 2006
Will the AOD bolt into a 1986 Ford LTD? I have a guy intersted in buying mine and I need a deffinate answer thanks
83Mustang427TT
162
  • Jun 16, 2006
What engine? 302 yes it will bolt in you need the floor shift from a v-8 mustang or if its column shift you have to fiddle with the linkage most likely but it will bolt right into a 302 the Ltd is a variation of the fox platform I think.I have seen people bolt alot of mustang things on them even a mustang GT front end and 95 mustang front brakes
5.0 con-vert
No soup for you, Joe Rogan!!!
Jun 7, 2005
244
Boca Raton, FL
Jun 16, 2006
  • Jun 16, 2006
The tranny itself will fit without an issue. However, the linkage on the LTD style AOD has a straight linkage for the shift cable and the stang one had a c-shaped one. Its either that way or the other way around. But that is the only issue. Everything else will bolt up just fine.
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
D
Ford AOD Transmission filler tube orings
  • Dagasser
  • Jul 21, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 26, 2026
D
AOD TV cable replacement bushing - loose pin?
  • DuluthFoxbody
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 2, 2026
DuluthFoxbody
D
D
AOD with 4R70W Internals and a Shift Kit - 1 to 2 Shift Question
  • Davjake128
  • May 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2026
Davjake128
D
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
