Quick question
I went to see a 90 hatch for a friend of mine. Overall the car was in good shape and looked well taken care of. I would like some opinions of the problems I saw and see if it's worth the trouble.
1st the check engine light is on: the dude said it was because of the o/r h-pipe and it's been on since then. When I put mine on my light never came on but I have an SD car is there a difference? I didn't think so. He said he never tried resetting the computer could this be the prob? Or worse?
2nd after a quick spin I pulled the dipstick to check the oil color and it was fine but there was some smoke coming out of the dipstick hole. What could that be? The car has sat for a while could it be condensation? My fear is the rings are gone/going but there was absolutly NO smoke out of the pipes (and I had the guy rev it while I stood out back) and the car wasn't running hot but the dipstick was pretty warm.
Any feedback would be appreciated
Thanks
fox bodies dont care about offroad pipes unless the o2 sensor isnt plugged into the harness. i forgot to plug mine in on one side before and the thing went off.
and about the dipstick, i've never heard of that. maybe just dirty old oil? the dipstick just goes into a tube which goes straight into the oil pan... was the car low on oil?
if you cant determine the source of the check engine light, either borrow or go buy a thing at pepboys or auatozone that pulls the codes from the OBCD (computer harness in engine bay). then check the codes and see if it's anything major. it comes wiht a book so you should be able to tell on the spot.
yeah i'd pull codes...search for jrichker and he has several posts on how to pull codes w/ just a paperclip.
the smoke out of the dipstick tube is prob just oil burning off of the hot tube...I pulled mine the other day and it did the same thing...kinda wondered why myself, but after thinking about it, prob. just oil burning.
my o/r h pipe does not produce a code by the way, like someone said, maybe if the an o2 isn't hooked up or is bad or something.
