quick question
bill302
2,131
alabama,gadsden
remove pan,remove differential pinion shaft lock bolt,pull pinion shaft out of differential unit,then push the axle shaft in and remove the c clip retainer with a needle nose plyers are you going to replace the axle bearings and/or seals....
