quick question
  • Thread starter Thread starter mustangman666
  • Start date Start date Mar 8, 2007
M
mustangman666
10
  • Mar 8, 2007
Alright i can get an amazing deal on a mac pro chamber H pipe. The only catch is it's from an 03 mach 1 and i have an 02 GT. The question is will it bolt in the same way as one designed for the 02? I thought they were basically the same but i did some research and have read a few different things. Could someone clear this up for me, i need to know before the deal passes. Thank you in advance to anyone that can answer my question.
ZIncGTSTANG
34
  • Mar 8, 2007
http://www.macperformance.com/store/product1.cfm?SID=3&Product_ID=237
99-04 GT/Cobra so I'd say thats proof.
M
mustangman666
10
  • Mar 9, 2007
^^^ That's what i thought too but i read on here that they were different. I just wanted to make sure before i got it. I know the cobras are different but i wasn't too sure about the mach 1.
four six
506
Hobart, IN
Mar 9, 2007
  • Mar 9, 2007
It'll work. I put my X on from my bro's mach 1
M
mustangman666
10
  • Mar 9, 2007
alright cool. now i've also read that using an H-pipe will not give you much low end torque or power. how do you restore the lost power? is there an easy bolt on part that will help will the low end?
BurningRubber
1,865
24
58
Mar 9, 2007
  • Mar 9, 2007
H pipes and Prochambers are generally the ones that will retain low end grunt.
Its X pipes that tend to lose a little low end to gain some high end.
M
mustangman666
10
  • Mar 9, 2007
well i got it in today and it sounds crazy. is there any way i can gain more low end power easily though? it feels a little more slugish off the line than it use to. any ideas?
merc123
420
North GA
Mar 9, 2007
  • Mar 9, 2007
Whenever you remove the cats (like with the PC or H-pipe) you will lose some torque. I would get some gears
M
mustangman666
10
  • Mar 9, 2007
See i would get gears but it's a daily driver and i'm on the highway frequently. As i understand it, swapping in new gears would change the speedometer reading and would give me higher rpm's at highway speeds. But on the other hand i NEED more low end grunt. What do you guys suggest i do?
Maza4ever14
187
Bay Area, CA
Mar 9, 2007
#10
  • Mar 9, 2007
  • #10
get 3.73s. Wont go off that much and freeway wont feel that bad.
kingc
85
Spring/Houston, TX
Mar 10, 2007
#11
  • Mar 10, 2007
  • #11
I totally second the 3.73's my gas mileage got better when I switched to 3.73's that may sound nuts but it happened...
M
mustangman666
10
#12
  • Mar 10, 2007
  • #12
so 3.73's wouldn't hurt the top end at all? would these be good or is there a better/cheaper place to get them from?
http://www.stangmods.com/Ford-Racing-Gears-p/00331-m4209f373n.htm
i already have an u/d pully set coming so hopefully that'll help too.
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
