Quick question.
  • Thread starter Thread starter RedFox5.0
  • Start date Start date Jul 2, 2008
R
RedFox5.0
PA
Jul 2, 2008
  • Jul 2, 2008
I have a 98Gt stock at the flywheel they have 225hp.
Now, I hopefully am getting PI heads soon, and after I get those before they get installed I am going to get Crower Stage 2 N/A cams, and aftermarket intake. I already have Flowmaster Cat backs, UD Pullies, and Cold Air intake. Is it crazy to expect somewhere in the neighborhood of 350 crank hp after I do all of this? I hear the PI swap gives you like almost 60hp because it ups the compression too. The cams on a PI engine give you in the neighborhood of 45hp (MM&FF), and what does everything else give me.
So 350hp or no?
StangYellow
1,052
Jul 2, 2008
  • Jul 2, 2008
The PI heads will raise your compression a tad because they arent dished. You can probably assume 3-5hp more than a 99+. However, that doesnt hold true if you have a high mileage/tired engine anyways. Secondly, depending on those cams, you might need to swap in dished pistons to accommodate the increase in lift/duration. Seeing 45hp through cams with pullies, muffler and an intake is a bit high. If you add the heads, those cams and dish the pistons, id guess your car would put down 260-270 rwhp at best
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jul 2, 2008
  • Jul 2, 2008
not gonna happen!!
350 @ the crank is close to 300@ the wheels.......better get some spray!
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Jul 2, 2008
  • Jul 2, 2008
350hp at the crank is a tall order for a N/A 4.6, 300hp at the crank is close to where you will be
spitfirees20
38
  • Jul 2, 2008
SaleenGT2001 said:
not gonna happen!!
I was looking at your cardomain for your mods, and then I saw this in the comments section:
"Posted by: ONESIK95
05/18/2007, 02:01am
Very nice looking keep me updated. Come check out our 1995 GSX 2.3 Stroker 587.39 HP @ 24psi on race gas. Also check out our 1992 GS-T Pro Touring Racecar. Vote and give us feedback on what you think in our guestbook. Thanks again and keep up the good work!!!
~Road/Race Engineering"
587.39 HP at 24 PSI on RACE GAS, then just to make sure I came back here and checked out your hp / tq #'s ... good stuff
R
RedFox5.0
PA
Jul 2, 2008
  • Jul 2, 2008
Dang this modular engine stuff is depressing I just want a fast street car.
http://www.musclemustangfastfords.com/tech/mmfp_0703_ford_engine_performance/index.html
These guys got 50hp out of those cams and I don't know how they did it. I'd like to be at atleast 325 crank hp. Dang.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jul 3, 2008
  • Jul 3, 2008
it's a magazine, they get paid to inflate numbers so the product sells more. if you were FI you can easily pick up 50 rwhp from cams
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Jul 3, 2008
  • Jul 3, 2008
Mods in my sig net the HP/TQ in my sig. You might see some gains over mine with more aggressive mods but 110 HP is a long way.
StangYellow
1,052
Jul 5, 2008
  • Jul 5, 2008
They also got 20HP from the Plasma Booster.
If we all installed everything MM&FF tested over the years, we would all have 450hp race cars.
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
