Quick Question
  • Thread starter Thread starter Five04sho
  • Start date Start date Feb 24, 2009
Five04sho
11
  • Feb 24, 2009
Hey guys whats up. I have had 7 stangs before this one I just picked up today. Heres the stats of the car: 1990 mustang clean motor was rebuilt about a year ago pistons,rods,bearings,bored30 over,cam,lifters,stahl converter, and has offroad h and flows. Anyway, what I need to know is, will it hurt the car if I accidently put 87 octane in it? He called AFTER i put the gas in and said "hey did you put premium in" i told him no and he said it should be fine, and just to put octane booster in it. Then I got talking to my other freind and he said NOT to run it hard until I get the 87 octane out of there otherwise I could have problems. Do I have anything to worry about here?
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Feb 24, 2009
  • Feb 24, 2009
whats the timing set at?
Five04sho
11
  • Feb 24, 2009
That I can not tell you. I can call him tomorrow and find out. Also, I should probably ask him what compression its running too huh? Anything else I need to know?
L
lang williams
567
cleveland, oh
Feb 24, 2009
  • Feb 24, 2009
back the timing down to 10 degrees, drive it easy an when the gas goes down to 3 quarters, refill it with 93 or 94. repeat. run 91 or higher.
OurBlue95GT
New Hampshire
Feb 24, 2009
  • Feb 24, 2009
When I got my car from my dad, he said to only run premium in it cause of the way it was timed. He said it wont hurt to put in 87, but it will ping like a bitch if you continue to run 87 in it. Esp. if you're stomping on the gas. Hope this helps some!
Have fun with your new toy!
Five04sho
11
  • Feb 25, 2009
Thanks guys, I'll throw the octane booster in it for now and when it starts getting to about 3/4 ill keep putting premium in it until it gets the old gas out. thanks!
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Feb 25, 2009
  • Feb 25, 2009
so it's N/A? no bottle either right? well no reason just be easy on it keep your foot out of it and when you empty the tank run the high test like your suppose to. if you want and if the car will run on lower octane,back the timming out and use lower octane. you will loose power by retarding the engine but then you can run lower octane? up to you just be easy with 87 in it peace
john
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
P
Progress Thread New To Me 1988 GT - trying to set up vacuum lines for upper intake question
  • pindude80
  • May 6, 2025
  • 9 10 11
15K
Fox 5.0 Mustang Tech Mar 28, 2026
pindude80
P
U
Knowledge Sought
  • USMCE3ROFP
  • Dec 6, 2025
  • Other Auto Tech
Other Auto Tech Dec 6, 2025
USMCE3ROFP
U
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
