quick questioncar
  • Thread starter Thread starter jimc347
  • Start date Start date Nov 14, 2005
J
jimc347
77
  • Nov 14, 2005
i put a brand new battary in my car. starts runs for 5mins then battary[ is dead. what to check???????
HISSIN50
34
129
Nov 15, 2005
  • Nov 15, 2005
A new battery does not mean a charged (or even good) battery.
But do you have alternator output? On a car that is off, put your DMM on the battery terminals. Look for ~12.6 volts. Once started up, look for 13.5+ volts. If you are below 12.6 volts while the car is running, you are running off the battery.
Good luck.
jaymac
995
Northern Mass
Nov 15, 2005
  • Nov 15, 2005
HISSIN50 said:
alternator.
Good luck.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Nov 15, 2005
  • Nov 15, 2005
If the alternator proves to be good, you could have a bad DIODE. This little device prevents the battery from being drained when the car is off.
jaymac
995
Northern Mass
Nov 15, 2005
  • Nov 15, 2005
also, make sure no loose wiring connections or wires are present. I had a wire that was not seated all the way in the harness for the alt., and the battery would die within seconds. It didn't look loose, but it was....
J
jimc347
77
  • Nov 15, 2005
okay thanks alot
CoupedUp
Banned
Aug 26, 2005
260
Gone Fishing
Nov 15, 2005
  • Nov 15, 2005
srothfuss said:
If the alternator proves to be good, you could still have a bad DIODE. This little device prevents the battery from being drained when the car is off.
Just to expand on what he's talking about ...
A diode is a one-way valve for electricity.
The diode only allows current to flow in one direction.
A/C = alternating current
D/C = direct current
An alternator generates alternating current (a/c).
The diodes in the alternator "turn" the a/c into d/c to recharge the battery, because a battery is a D/C circuit power source.
Like srothfuss said, if a single diode or group of diodes (rectifier) is shot it can discharge your battery quick enough. A fully charged battery usually takes longer than 5 minutes though.
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
Electrical Parasitic Draw, Fuse 8
  • N8827N
  • Sep 15, 2026
Fox 5.0 Mustang Tech Sep 18, 2026
AeroCoupe
