OKAY GUYS I GOT HER RUNNING GREAT NOW!!!!!!!! The only thing left was when I went to put her in reverse it would grind so I didn't push. I am assuming my clutch isn't engaging all the way. It is a JMC hydraulic clutch, what would cause this. It has been bled properly and I thought I had used the adjusting nut enough. Should I take a wrench and tighten it to the point where the throwout bearing is slightly pushing on the pressure plates fingers. Please hurry guys, this is the only thing that is left before I get to drive it.
I adjusted the nut all the way, the thing is when we press on the clutch in moves an inch where I think it should move 1 7/8 inch to properly engage it. I have the throwout bearing firmly touching the fingers on the pressure plate. I have gravity bled it for a day so I figure the bleeding is good.
