  • SN95 4.6L Mustang Tech
Quick/Simple Question
  • Thread starter Thread starter d98gt
  • Start date Start date Aug 15, 2006
d98gt
4,505
59
204
SE Texas
Aug 15, 2006
  • Aug 15, 2006
I need to get the tensioner off so I can change the pulley, though I let a friend borrow my 1/2" and the jackass left town and won't be back until tomorrow.
Is there any way that I could remove the tension to remove the belt? Also, since the tensioner is spring loaded, i'm not going to need to worry about the spring coming out or any thing like that when I pull it off, correct?
I'm not looking to go out and buy another 1/2" since I do have one. I just need to remove the tensioner to replace the squealing pulley
Jinx
I like cats, cats like me. Cats and I fully agree.
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Aug 15, 2006
  • Aug 15, 2006
Vicegrips and a metal tube
d98gt
4,505
59
204
SE Texas
Aug 15, 2006
  • Aug 15, 2006
I wonder if I just pulled the 3 bolts (or however many there are) since they have to come off anyways, if that'll work
Surely someone can chime in to help out a dumbass
d98gt
4,505
59
204
SE Texas
Aug 15, 2006
  • Aug 15, 2006
Alright, had someone drop off a 1/2" for me.
Now I need to remove the bolts, anyone know the size? I don't have any deep sockets so I might have to use a wrench
DTNODYA
831
  • Aug 15, 2006
I can't remember the size but all you do is take the bolts out. I want to say it was like a 12, 13, or 14mm ... been a while. You don't have to worry about any tension issues (when your belt is off there is not tension on the pulley to snap back) if that makes sense. I assume you probably know that but thought I'd clarify incase you didn't.
If you don't have any deep sockets I'd put on some gloves first because you will most likely bust some knuckles using wrenches. Get a bar or something sturdy that will fit over the end of the wrench to break them loose if you can't by hand.
d98gt
4,505
59
204
SE Texas
Aug 15, 2006
  • Aug 15, 2006
Simple jobs like this usually kick my ass as proved today
One of the nuts got stripped, however I replaced it. It took me a bit to remove but now that I've done it, it's pretty simple. O'Reilly gave me the wrong part which put me in squeeze though once I got the right part everything worked out just fine
DTNODYA
831
  • Aug 16, 2006
Did you change both of them? The idler pulley connected to the tensioner sounds like the one you changed (more difficult than the other pulley to change but not really difficult). Reason I ask is because I changed out only one of mine and the other one started that damn sqealing so I replaced it and no more issues. FWIW, the pulley is the same part as the one you replaced .. I'm talking about the pulley above it in case my post is confusing
BennyBlown2v
1,233
Carmel, INdiana
Aug 16, 2006
  • Aug 16, 2006
Get under the car and use a stick, dowel, or broom handle and push on the tensioner - i have to do it that way with the blower.
d98gt
4,505
59
204
SE Texas
Aug 16, 2006
  • Aug 16, 2006
I only changed the tensioner pulley for the time being as it was the only one squealing. The idler pulley will be even easier since I won't have to remove any parts.
Belt Tensioner Question...
  • robw13
  • Mar 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 10, 2025
gkomo
Forced Induction V3 pulley change
  • JD1964
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 21, 2025
JD1964
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
Fuel 1990 installing edelBrock intake
  • Beaker
  • Oct 5, 2026
Fox 5.0 Mustang Tech Oct 6, 2026
