Quick wheel question
  • Thread starter Thread starter MustangGlx
  • Start date Start date Aug 18, 2007
MustangGlx
147
Connecticut
Aug 18, 2007
  • Aug 18, 2007
Whats the absolute widest you can go on a foxbody in the rear with wheels/tires? Quad shocks are removed, and i wouldn't be horribly opposed to rolling the inner lip of the quarter out of the way if it was worth it. Thanks
-Joe
grey5.0beast
Cookies should never be DUNKED!!!
Aug 3, 2004
atl ga
Aug 18, 2007
  • Aug 18, 2007
NKau
1,346
Jefferson, WI
Aug 18, 2007
  • Aug 18, 2007
Depends on the car. Hatchbacks have the most room in the rear wheelwells, with notches and convertibles having a bit less room supposedly. What size wheels/tires are you looking to run?
fiveohwblow
Official Member
2,169
145
155
Aug 18, 2007
  • Aug 18, 2007
I have 9" rims with 275 and I am good unless I get some weight in the car. I should also mention I have lowered it about 1.5 inches as well...
MustangGlx
147
Connecticut
Aug 18, 2007
  • Aug 18, 2007
I've got an 89 LX hatch which i guess means i should have more room, but i want to run as wide as i can, traction is going to be a major concern for me when the car is finished
NKau
1,346
Jefferson, WI
Aug 18, 2007
  • Aug 18, 2007
You plan on running a small or larger diameter wheel? Guys get away with 275 series radial tires on 17x9's pretty routinely out back. I had 255/50 series drag radials (dr's have a bit of sidewall bulge) on some 16x7 ponies, and would rub occassionally when cornering hard and hitting a bump at the same time (car was still factory ride height). Kind of hard to answer your question without knowing what rim diamter you want as it does make a difference in terms of tire size you are able run.
MustangGlx
147
Connecticut
Aug 18, 2007
  • Aug 18, 2007
Im not sure,still kind of looking around at what i want to do, but i was thinking about running a staggered 95 cobra r wheel set, 17x10.5 rear 17x9 in the front, would that fit if i rolled the inside lip of quarter out of the way?
grey5.0beast
Aug 3, 2004
atl ga
Aug 18, 2007
  • Aug 18, 2007
Might have to do some "massaging". Or go mini tubbed
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
305-45-17 tires on Pony wheels (17")?
  • TTSaleen
  • Mar 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 25, 2026
TTSaleen
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Saturday at 8:51 AM
Rdub6
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
