R & R Help Power Window Motor
Sompin2do
59
TX
From all of my searching here it seems like it's time to R&R the driver side window motor (I hit the switch, window doesn't move, power at the gauge drops, and I can hear a slight click inside the door) on my 94 GT.
Chilton manual is descriptive enough for pulling the door apart, but can't find anything about replacing the motor. I've done these before on a Bronco, but not a Stang.
Any pointers would be helpful.
Thanks
Mike
check the help section in your local auto parts store. they should have them there. I think there were like 3.99. You'll see once the motor is apart if the pins are the problem and they most likely are.
This morning the window is working fine. Just to clarify my first post. That clicking I could hear was very faint. Could it still be the pins? Thanks for the replies.
Mike
