  • SN95 4.6L Mustang Tech
radar detector mod
  • Thread starter Thread starter shaddixstang
  • Start date Start date Apr 13, 2004
shaddixstang
66
Destin, FL
Apr 13, 2004
  • Apr 13, 2004
This can be done if you have allready done the fog light mod.
I bought another factory fog light switch and installed it were the convertible top switch goes. Forgot which pins are what on the switch. I do know there is and ACC, +12V, GRD, and Headlight signal. Made my own wiring harness and spliced in to fog light wires. Then cut cigarette lighter connection off radar detector. Mounted detector above rear view mirror and ran wire down a pillar and through console to switch. Connected +12V to ACC on switch and ground to any common ground. Can't remember where for sure.. probably on the switch. Now my radar detector is switched and comes on only when the key is on and switch is on plus the lights in the switch work just like the fog light switch. Great for quickly turning off the radar detector in town. Also don't have to worry about unplugging it. Will try to get wiring diagram if I can find it. Hope this is useful to someone.
Jon
JonJon
4,801
back in Marylands
Apr 13, 2004
  • Apr 13, 2004
Now that's pretty cool
I may want to do that, for the neat factor
pony_vert02
285
AUSTIN,TX
Apr 13, 2004
  • Apr 13, 2004
dude! kick ass!
Bulldog6Z6
163
Houston Texas
Apr 13, 2004
  • Apr 13, 2004
I got mine fused into the ignition at a car audio place for like 15 dollars does pretty much same thing except u cant turn it on and off. it turns on and off when u start the car
shaddixstang
66
Destin, FL
Apr 14, 2004
  • Apr 14, 2004
Maybe I confused people a little when I said it works if you have done the fog light mod. It will still work if you don't but you need to get your +12v for the switch from the convertible harness and just remember to connect your hot to detector to ACC on the switch. The rest you just splice into corresponding wires on the factory fog light switch. This makes the detector come on when you turn the ignition on as long as the switch is on. I mounted my detector where I did because I have to go on base every day and they make you take it off if they can see it.... hehehe.
Jon
ZIPP0
781
Philadelphia
Apr 14, 2004
  • Apr 14, 2004
sounds very cool
Snarf
237
Lexington, KY
Apr 14, 2004
  • Apr 14, 2004
Wow man that sounds awesome I'm definetly gonna do this when I get me a detector. Sorry for going off-topic, but whats the foglight mod yall are talking about?
shaddixstang
66
Destin, FL
Apr 14, 2004
  • Apr 14, 2004
Its for 94-98's. the fog lights only work with the headlights on. There is a way to get them to work without turning on headlights but retains the factory switch. If you have a coupe you tap into the convertible harness for power.
Jon
Marine One
276
North Topsail Beach, NC
Apr 16, 2004
  • Apr 16, 2004
Jon
That mod can also be done if you have a convertible!
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
W
Interior and Upholstery New Member auto dimming mirror install issue
  • WigSnatcher92
  • Aug 25, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 28, 2025
Mustang5L5
Electrical Test headlight switch
  • Dontknowchit
  • Mar 25, 2024
3K
Fox 5.0 Mustang Tech Apr 1, 2024
Dontknowchit
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
J
2000 Ford Mustang GT No Crank No Start please help
  • Jowen216
  • Jun 5, 2024
3K
SN95 4.6L Mustang Tech Jul 5, 2024
Jowen216
J
