• Community Forums
  • Regional Forums and Event Information
Radiator cap pressure question
  • Thread starter Thread starter saleenster
  • Start date Start date Jan 5, 2006
saleenster
2,621
Vancouver, WA
Jan 5, 2006
  • Jan 5, 2006
I got a new Fluidyne radiator, but I am not sure what lb pressure cap to get. They have 16 lb, 19~21 lb and a 24 lb...I have no experience with cap and lb pressure, so any advise would be great for my application
Cory
WaterPog
2,201
Portland, OR
Jan 5, 2006
  • Jan 5, 2006
get the low pressure one. It's easier on the system and will be less prone to inducing leaks.
The purpouse of the higher pressure is to increase the boiling point so unless you're having issues there isn't any benefit.
saleenster
2,621
Vancouver, WA
Jan 5, 2006
  • Jan 5, 2006
Tks Pog
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Jan 5, 2006
  • Jan 5, 2006
saleenster said:
Tks Pog
What kind of 3core is that i see F/S? do you still have the squarters? peace
john
saleenster
2,621
Vancouver, WA
Jan 5, 2006
  • Jan 5, 2006
john
Dont know what you mean by "squarters", but its a motorsport 3 core with cap. I had it on the car for almost 2 yrs...or less then 4K if that helps
ddonaca351
2,055
Camas Washington
Jan 5, 2006
  • Jan 5, 2006
C-moneeeyyyyyy.... wazzz-up?
If I remember right, I think it's like 3 degrees of boiling resistance for every lb of pressure.
If youre worried at all, you might check into some of the new synthetic coolants that summit has (or jegs, or b.o.p or whoever) they dont use any water, so the boilover protection is quite a bit higher, and they're ok with alluminum.
DD
T
time only
461
Miami,FL
Jan 6, 2006
  • Jan 6, 2006
16 psi
I am also putting in a Fluidyne radiator in between rain shower,might never get done if the sun don't come out . I am using the 16 psi cap,I was told anything higher will kill a head gasket.
saleenster
2,621
Vancouver, WA
Jan 6, 2006
  • Jan 6, 2006
DD
Tks DD, 3 degrees for every lb sounds about right after looking at the figures. I purchased the 16 lb cap yesterday.
Time only, Good luck
fiveohwblow
Official Member
2,169
145
155
Jan 6, 2006
  • Jan 6, 2006
I am pretty sure I just put my stock radiator cap on my Fluidyne and have been runnin it for quite some time now without problems... What is the need for a new cap?
saleenster
2,621
Vancouver, WA
Jan 6, 2006
#10
  • Jan 6, 2006
  • #10
Justin, I did not know what the lb reading of the stock cap is/was, and with the overheating issue I just endured, I am much more comfortable in starting with a foundation of things I know vs not knowing
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Jan 6, 2006
#11
  • Jan 6, 2006
  • #11
So you got a new radiator because you were over heating? Does this also mean there is nothing wrong with the other one you have F/S? I ment do you still have the injector's? peace
john
saleenster
2,621
Vancouver, WA
Jan 6, 2006
#12
  • Jan 6, 2006
  • #12
john
What the hell did you just post dude? I meant nothing as I said nothing
C
03 Cobra Low Fuel Pressure
  • CTsnake_03
  • Mar 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
CTsnake_03
C
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
How do we feel about first gen fuel caps?
  • Teen'93stang5.0
  • Apr 25, 2026
  • Mustang Sound & Shine All
Mustang Sound & Shine All May 3, 2026
General karthief
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
  • Community Forums
