Radiator from a 94, 95 fit
  • Thread starter Thread starter Jack's95gt
  • Start date Start date Dec 20, 2005
J
Jack's95gt
443
Huntingdon Valley, PA
Dec 20, 2005
  • Dec 20, 2005
Will a radiator from a 94 or 95 Mustang work in the fox body?
bill302
2,131
alabama,gadsden
Dec 20, 2005
  • Dec 20, 2005
my information says no the core support system is different changed in 93. you will need a 79-93. you could make it fit but that would take alot of fabrication to core support but i would not do that.
HISSIN50
34
129
Dec 20, 2005
  • Dec 20, 2005
That SN95 radiator is about 3/4" thick - it is pretty useless.
Look at a fox HD unit (3 core) from the parts store, an aftermarket unit, etc.
Good luck.
bill302
2,131
alabama,gadsden
Dec 20, 2005
  • Dec 20, 2005
Good luck.
and cost's twice as much new.
J
Jack's95gt
443
Dec 20, 2005
  • Dec 20, 2005
I'm dropping in the 95 gt motor into the 93 lx 2.3 car. I bought a new set of Goodyear Blue Hi Miller hoses in the 94-95 design. The top inlet to the radiator is much smaller that the hose. I was hoping to just purchase a 94-95 radiator, but now it looks like it would be more trouble than it's worth. I read somewhere that the 2.3 and the 5.0 uses the same radiator, thats why I was looking at the 94-95. I guess i can just clamp down on the hose clamp and see if it seals.
HISSIN50
34
129
Dec 20, 2005
  • Dec 20, 2005
Can you not use a fox radiator with the 94-95 motor (in your application)? It does not sound like the radiator you have now is the same as a 5L fox. As I recall, the inlet for both 5.0 set-ups was 1.5" inlet and 1.75" outlet. I very well may be wrong on that recollection though. Double check all that.
Another issue could be that in order to achieve enough surface area in the coil, the SN95 radiator is very wide. I dont know how that would package on a fox.
EDIT: I just read your sig. I would just measure away on your fox project to see if the SN95 radiator will fit. Since you already have that radiator, I see why you want to use it (in my previous post, I thought maybe you did not know how anemic those stock SN radiators are - but you have one. LOL).
You would probably have to fab up feet and saddles since I bet the fox and SN radiators dont have the same mounting perches.
Well, this post helped none at all. Just randomly brainstorming with ya. Good luck Jack.
Flushing water from the radiator and block.
  • djj62478
  • Oct 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 11, 2026
CAMTWO1070
99 mustang gt 4.6 excess cooling system pressure
  • Blackbeauty99-4.6
  • Nov 11, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Saturday at 12:47 PM
Mustang5L5
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
