Radiator Help!!! 1998 GT
Get E Up 98
144
I looked in my garage tonight and found a puddle under my car...as you can see from the pics it is leaking from that black rubber piece. It is sort of a slow leak. Is that rubber piece a plug? Anyone have any ideas? As you can tell and see there are water spots under the car and on the floor. I fiddled with it some and it stopped leaking...im baffled
:Damnit:
The drain is right above that rubber grommet to the right. It is shaped like a plastic nut. Make sure it is tight. Also, i think the drain plug may have a washer or "O " ring.
I had to get a new radiator because mine was leaking. I found out it was the gaskets that went bad between the plastic and aluminum that the radiator is made out of. It was a very slow leak. If you let it sit and run, it leaks out a lot faster. If that is the problem, it will be damp on the side of the radiator.
i would check the drain plug mine is shaped like a wing nut and look for cracks. i had to replace mine cuze it had a crack on the top by the hose and i thought the hose was bad but it turned out to be the radiator and that stop leak isnt worth a crap either!!
Well I removed the radiator tonight and this is what I uncovered...
It took me 15 minutes to take it out. How long will it take to install? We shall find out tomorrow. I ordered a new radiator tonight and it will be here tomorrow.
You're in the EXACT same boat as me! My leak was occuring where that plastic strip crimps over the aluminum on both ends of my radiator. Rather than replace I upgraded to the radiator used in the 03/04 Cobras -- all aluminum and 3 core. Randy Stinchcomb at Modular Depot hooked me up -- $219.00 shipped. Great price for a good upgrade. Hopedfully I'll get to the install this weekend.
it shouldnt take that long to put it back in all you have to do is take you fan off and put it on the new radatior and the clips at the bottom and bolt it up and your ready to put it back in o and make sure your drain plug is tight too!
