Radiator hose upper/lower collapsing
  • Thread starter Thread starter time only
  • Start date Start date Sep 23, 2008
T
time only
461
Miami,FL
Sep 23, 2008
  • Sep 23, 2008
I noticed this last few days that after I turned my car off,both the hoses starting to collapsing down until it is almost flat. I could hear the coolant draining back somewhere(The radiator or the engine )? After it cool down a bit the hose will bounce back to its old shape. I don't see a leak anywhere and the temp gauge is showing a little on the cool side ( 140'-160'F ) . I am running a 180'F thermostat.
What could be happening ?
HISSIN50
34
129
Sep 24, 2008
  • Sep 24, 2008
Have you replaced the rad cap anytime recently (or tested it)?
cevtv
1,113
Massachusetts
Sep 24, 2008
  • Sep 24, 2008
Make sure the overflow tank isn't clogged with sludge in the bottom....
cardudeusa
1,744
Home of the Florida Gators!
Sep 24, 2008
  • Sep 24, 2008
Are they cheep hoses or quality ones? I've had cheep hoses do that and replaced it with a factory hose and the problem went away.
T
time only
461
Miami,FL
Sep 25, 2008
  • Sep 25, 2008
Good call.. The hoses are from 5.0Resto. So I guess they are not the best around. I will drain and clean the overflow tank and see if it is the problem. The cap are about 1 years old. I will pick up a new one asap.
Thank you..Stangnet.
cardudeusa
1,744
Sep 25, 2008
  • Sep 25, 2008
time only said:
Good call.. The hoses are from 5.0Resto. So I guess they are not the best around. I will drain and clean the* overflow tank and see if it is the problem. The cap are about 1 years old. I will pick up a new one asap.Thank you..Stangnet.
If you have the cash the Ford Racing hoses are nice and hold up really well.
HISSIN50
34
129
Sep 25, 2008
  • Sep 25, 2008
The hoses are a symptom, not the underlying issue. More robust hoses might mask the symptom but the issue will still be there.
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
W
High Cylinder Head Temp - Not Overheating?
  • wtfwork12
  • Jun 26, 2025
2K
2005 - 2014 S-197 Mustang -General/Talk- Jul 1, 2025
wtfwork12
W
D
Resolved Upper radiator hose cold??
  • dqureshi06
  • Oct 31, 2024
2K
Fox 5.0 Mustang Tech Nov 11, 2024
limp
