There's an adaptor kit you can buy at most any car stereo store, though they may have to order it. It's made by Metra, model number 70-5514, and it's only $15-$25. Make sure you get the 94-98 Ford Premium sound system kit (same for Premium Sound and Mach 460). The Mach 460 kit available (70-5519) is only for 2000-2004 Mustangs - don't get it.
The problem with aftermarket decks is with the adaptor used. Basically, the head unit must make use of the Mach 460 amps, and NOT its internal amp. You have to wire up the pre-outs into the Mach 460 amp for it to work correctly. The generic wiring adaptors don't do this properly, and you end up over-amplifying the music. I've used the 70-5514 Metra kit above in my Mach 460 system, and I've had great success with it. No audio problems at all.
Instructions are vauge with the kit, but each wire is marked on the wire what it's for. Just splice all the available wires together between the Metra harness and the one that came with your head unit. If you end up with a few from the aftermaket harness that don't match up, that's OK. The important ones are all there.
