i got me a diffrent radio for the 95! (thanks to misha) so what i'm woundering is the one i got has a built in amp so since i have the mach 460 system in the stang can i still use the stock amps and the one from the radio? and if any of you have installed a new deck (ONLY) where did you get the harness to plug right into the new radio, i dont want to cut the factory wiring harness. i called car toy's and they said ummmmmmmmmmmmm dahhhh what????? i know these are made cause i put one in my civic but that was not as good of a stock system like the stang. so now yes i have a stock deck from the 95 i dont need. peace
john
john
98V6 K.I.T.T.
your mistake was calling car toys......call magnolia. I have the harness you are wanting although it might be used for my 02 when i have my kenwood put back in. the harness is about 40-50 dollars. Just call magnolia, tell them you have a 95 stang with the mach 460 and you are looking for the harness that filters the stock amps and it should be around 40/50 they will know. Car toys just uses the cheap 10 dollar harness and bypasses your stock amps.
