Has anyone used these ? > http://www.sdtrucksprings.com/index.php?main_page=product_info&products_id=6439
If so ,how much lift will they give ? Thanks
Drivers rear is 3/4" lower than Pass. rear.Tried hard rubber coil spring spacers.But even with car jacked up there's not enough space to install them.Tried a metal coil spring spreader.But not enough space to install. Someplace I read Fox bodies are known to have this condition.What little info on the page you may not get any lift unless your springs are sagging now.
What is your reason for considering them
No fox body has leaf springs. The term Fox body is synonymous w/ coils on all four corners. Show me an example of a 90's fox body w/ leaf springs, and I'll show you a car that is mistakenly labeled as a foxbody.Here is another question.Why do some fox bodies( Of the same year)( have in the rear) coil springs and some have leaf springs ?Example, you can find 1990 s with either/or.
Then why do they sell them ? https://www.mustangdepot.com/OnLineCatalog/Suspension/leaf_springs.htmNo fox body has leaf springs. The term Fox body is synonymous w/ coils on all four corners. Show me an example of a 90's fox body w/ leaf springs, and I'll show you a car that is mistakenly labeled as a foxbody.
If you have one side lower on your car something is either worn out or broken. Mustangs get beat on and torqueboxes fail. when the floor starts to tear where the mounts are, the chassis sags. If a control arm bushing is shot, the car doesn't sit right either. Lastly, the coils themselves just wear out. Typically the passenger side coil has had to deal w/ torque transfer it's whole life,....it wears differently than the driver's side.
The reason that there is so much info out there about the car sagging on one side is because they are over 30 years old, and by nature have more than likely been beat on at sometime in the car's past. And the reasons for the above are all attributable to one of the three.
Lift up carpet, check that your torque boxes haven't started to tear out. Look at the floor mid point to be sure that a tear hasn't started there as well. Replace the control arms, or the bushings, change out the springs w/ new ones and install SF connectors if they are not there already.
For god sakes do not raise the car up w/ a stiff spring or a freakin airshock....It'll ride and handle like ass, all while looking stupid at the same time. The 70's are dead. Gabriel High-jackers died right along w/ N 50-15's, Boston,..and leisure suits with them.
The ad is listed as 65-73...65-73 are not foxbody cars/ Fox body started in 1978.Then why do they sell them ? https://www.mustangdepot.com/OnLineCatalog/Suspension/leaf_springs.htm
Boston is dead?
You need to get with the program ! Therese only ONE rock group Baby . And this is them !!! Boston ? What the ---- is Boston ?You need to get with the program ! Therese only ONE rock group Baby . And this is them !!!
View: https://www.youtube.com/watch?v=TuCGiV-EVjA
