  • SN95 4.6L Mustang Tech
ran 13.4 with KB???
  • Thread starter Thread starter Bundmar
  • Start date Start date Jul 21, 2005
Bundmar
377
Ontario, Canada
Jul 21, 2005
  • Jul 21, 2005
I went to the track for the first time with my KB installed and only ran a
13.4 @ 112MPH. I know I need DR's bad, but still shouldnt I do better on street tires?
what is everyone else with the KB 9PSI running at the track?
60' 2.347
1/4 13.472
MPH 112.19
Ive dynoed at 387RWHP and 390RWTQ
slo65
448
Southern California
Jul 21, 2005
  • Jul 21, 2005
those 60's are pretty bad, just get some real dr's like some mt's or something, cut a 1.7 and u have a mid 12 second run
streetstang03
unModerator
Dec 27, 2003
the dark side of the moon/home of the 1999, 2003,
Jul 21, 2005
  • Jul 21, 2005
definetly need to get that 60' down.
sgarlic
3,085
Jul 21, 2005
  • Jul 21, 2005
What RPM did you launch at? Did you slip the clutch in to first or just drop it?
ADRENLN
2,342
NJ
Jul 21, 2005
  • Jul 21, 2005
i still think that you should be able to run better then that with all that power. yes if you get the 60 down you will run better thats obvious.
a regular corvette for ex. can run in the 12s with no mods and less power, why is this? is it just that their weigh distribution is that much better? i would think that you be able to smoke a regular vette with that kind of power.
dkshadow
Banned
May 12, 2003
952
TEXAS
Jul 21, 2005
  • Jul 21, 2005
No doubt youre having traction problems, just look at your trap speed. How about some LCA/UCA and DRs as well? This would be a good time to upgrade to 31 spline
tomustang
Psychotic Member
3,434
McLean Hospital
Jul 21, 2005
  • Jul 21, 2005
You ran 112 and your complaining? Need to work on your launch.
02 Mineral Gray
100
Atlantic City, NJ
Jul 21, 2005
  • Jul 21, 2005
Get those 60 times down and you will be happy..
mogs01gt
3,113
30
119
Ohio
Jul 21, 2005
  • Jul 21, 2005
not a bad trap speed for a heavier vert. Well now even heavier in the front with that KB on it.
it will be hard launching with all that torque I bet.
back_in_black
460
frederick, MD
Jul 21, 2005
#10
  • Jul 21, 2005
  • #10
I know if you put a set of decent dr's and work on your launch you will do much better
StratGT
477
Mississauga, Canada
Jul 21, 2005
#11
  • Jul 21, 2005
  • #11
You got 4.10's and a KB at 9psi. You'll need sticky tires for sure. Have you considered dropping down to a 3.55 gear?
back_in_black
460
frederick, MD
Jul 21, 2005
#12
  • Jul 21, 2005
  • #12
good point, kb reccomends 3.73's, I do think the 4.10's are too high for all the low end torque.
AmBo
1,027
New Jersey
Jul 21, 2005
#13
  • Jul 21, 2005
  • #13
omg 4.10s with a 9psi Kenny kit?! Wasn't it wierd shifting into 5th about 3/4 way down the track?
Z28 KILR
386
Columbus, OH
Jul 21, 2005
#14
  • Jul 21, 2005
  • #14
I ran 13.2 at 111 mph with 3.73's and a Vortech S-trim. This was on street tires also. Get some Nittos and be in the mid to high 12s.
Bundmar
377
Ontario, Canada
Jul 21, 2005
#15
  • Jul 21, 2005
  • #15
well I have my rev limiter raised so I can finish the 1/4 in fourth,
Ive ordered 31 spline axles, Nitto DR's and Steeda UCA/LCA so Im hoping to get to mid 12's,
no traction in 1st or 2nd, Im letting the clutch slip cant hammer on it or it just spins,
Im happy with the MPH but want to run mid 12's
there was a S/C Z06 and he was running 12.4 @ 119
Ive beat stock 03/04 cobras on the street but Its alot harder on the track
Ill post what I run with the Dr's installed
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jul 21, 2005
#16
  • Jul 21, 2005
  • #16
no need too do that.. why not just get a taller slick/ drag radial. this acts like lowering the raito no need to demod the car.
T
tooblue02
86
Groton Connecticut
Jul 21, 2005
#17
  • Jul 21, 2005
  • #17
.1 sec in the 60 = .2 in the 1/4, I ran a 1.86 60' and went 12.2 at 114, it's all in your 60. I also ran a 13.9 @ 112 with a 2.8 60' (epping is awsome!)
showstopper2
425
New Bedford, Ma.
Jul 22, 2005
#18
  • Jul 22, 2005
  • #18
I went a 12.7@113 my first time out with over 400rwhp and 400tq on the stock Goodyear tires. traction was very limited and I also managed a 2.0 60ft. you need to control the gas pedal some...
next month I hope to smash that time on DR's with a new clutch and built rear on board.
99RioRedVert
95
Chesapeake, VA
Jul 22, 2005
#19
  • Jul 22, 2005
  • #19
With 390 rwhp and street tires (on 18" rims) I went 13.4 @ 112 with a 2.4 60' time. On ET Streets and everything else the same, I went 12.2 @ 114 with a 1.7 60' time.
Traction is definitely the problem.
As far as gearing goes, I have 4.10 gears. For me, they are the perfect gear on the track. They help me stay in the powerband. My power doesn't come on strong until 4k+ rpm and I shift @ 6,500 rpm. With a KB and limited traction, 4.10 might not be as ideal for you. But, as long as you can get all the power to the ground (ie traction) and have a high enough rev limiter to stay in 4th through the traps, a numerically higher gear ratio will always be superior.
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
