Ran Codes With A PaperClip..Puzzled About One Code
  • Thread starter Thread starter 92GreenGT
  • Start date Start date Oct 18, 2004
1 of 2 Next Last
9
92GreenGT
PEAT
2,085
Big Stone Gap, VA
Oct 18, 2004
  • Oct 18, 2004
I ran codes today with a paper clip, did the KOEO and KOER test. The KOER test I got "111" which means System Ok. In the KOEO test I got a few flashes. I counted "85" two times, it make 8 fast flashes then a pause, then 5 more flashes, then a pause, then 8 again and then 5 again. So thats telling me "85" and it showed the code both times. I think that means its a hard fault but im not 100% sure, what confuses me is what Code 85 stands for. I looked it up and came up with something to do with auto trannies? Could someone help me with that, and is that what Code 85 is? After the Code 85 got thrown I got a few "11" code flashes, which means System Ok on that. So can someone explain what this code 85 is? Thanks
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Oct 18, 2004
  • Oct 18, 2004
Did you remove your canister purge control valve for the charcole canister? Or it may be bad or unplugged.
If you look at the 85 description it says M for memory and says CANP solenoid (ALL 1989) - Solenoids
RydeOn
Licensed to Chill
6,273
orange county, CA
Oct 18, 2004
  • Oct 18, 2004
Yes, 85 is a canister purge solenoid circuit failure. It is a KOER code as well.
88stangmangt
2,332
Stafford,VA
Oct 18, 2004
  • Oct 18, 2004
my book says it is related to warn out muffler barrings????
9
92GreenGT
PEAT
2,085
Big Stone Gap, VA
Oct 18, 2004
  • Oct 18, 2004
There ya go, thats exaxtly what it is. Never thought about that. I removed my canister purge valve soleniod, so im guessing that is my problems. That is the only code it threw.
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Oct 18, 2004
  • Oct 18, 2004
cool. easy fix...
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Oct 18, 2004
  • Oct 18, 2004
LOL
9
92GreenGT
PEAT
2,085
Big Stone Gap, VA
Oct 18, 2004
  • Oct 18, 2004
Well if the computer isnt showing codes, then I dont know what my problem is.
Seems the car just dont want to idle for anything. I set my TPS today and checked my timing and ran codes. Both came up good and the Timing was set to 10*.
I am out of ideas and test. The car has a VERY choppy idle and is only reading about 12 inches of vaccum on the gauge at idle. If I rev the car up to any RPM on rev down the car will go as low as 300rpm then shoot back up. Tomorrow when I go out and start it, the first two times it will die no matter what, then on the third time it will run. Im just confused as hell right now.
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Oct 18, 2004
  • Oct 18, 2004
give this a try http://www.50tech.com/articles/display_article.php?catid=8&id=4
9
92GreenGT
PEAT
2,085
Big Stone Gap, VA
Oct 18, 2004
#10
  • Oct 18, 2004
  • #10
I done that last week and I had the car to a seemingly good idle position. Its raining like hell out and its dark so im going to wait till tomorrow. I will redo that again now that I have adjusted my TPS to the correct setting. I will do all that tomorrow and let you guys know what goes on.
RydeOn
Licensed to Chill
6,273
orange county, CA
Oct 18, 2004
#11
  • Oct 18, 2004
  • #11
U got alot of mods tho dave. Did you custom tune and get a chip yet? I bet thats what you need to do.
9
92GreenGT
PEAT
2,085
Big Stone Gap, VA
Oct 18, 2004
#12
  • Oct 18, 2004
  • #12
Nope, havent done it yet...mainly becuase no one around can do that for me actually. I have a dyno close by but they cant burn chips.
One I get the idle figured out I should be ok. I have a few friends that done work like I have and they dont have a single problem. Must be something that messed up on me and I havent caught it yet. Just takes time.
I am going to hook all my esmissions stuff back up though. I hooked that soleniod back up and reset the computer and its still throwing the cod. So im going to hook everything back up and if it still throws it, im clueless. I dont think it hurts the cars performance though. I just need to get it running smooth and drive it straight for a few days and I think it will be fine.(hopefully)
9
92GreenGT
PEAT
2,085
Big Stone Gap, VA
Oct 19, 2004
#13
  • Oct 19, 2004
  • #13
Ok, I went out to give the car a new idle like suggested above. If the IAB is bad will it throw a code? Becuase the car just acts like it doesnt want to check an idle. When I had the car running I unplugged the IAB and the idle never changed. I am going to take it off and give it a cleaning and see if that helps it. At idle the car jumps around, it will go from 700-900 rpm in spurts. What is causing this? Damn car.
blk92stangg
583
Hawaii
Oct 20, 2004
#14
  • Oct 20, 2004
  • #14
No, I am pretty sure the IAC won't throw a code. 2 of my friends and I were chasing down a idle problem too. We were using on IAC from what we thought was the "good" car, and it didn't help, so we gave up. The "good" car's owner sprang for a new IAC on a whim, and wouldn't you know, the car runs like a charm now. I guess the IAC goes out so slowly that you think the car is running great, when really its running like crap. When my friend called me to tell me the news, from the tone of his voice, I would have sworn he was going to tell me that had just gotten laid.LOL.
blk92stangg
583
Hawaii
Oct 20, 2004
#15
  • Oct 20, 2004
  • #15
Just read my post and it sounds kinda of confusing. I was just trying to comment that the IAC is likely the cause for many a bad idle, and at under 50 bucks for an aftermarket piece, its worth taking the chance. Especially considering how irking a bad idle is. GL
9
92GreenGT
PEAT
2,085
Big Stone Gap, VA
Oct 20, 2004
#16
  • Oct 20, 2004
  • #16
I am pretty sure that is my problem. Like you say, it goes downhill slowly. I got it running about as good as possible right now, still just a few misses and little things. Pretty sure a new IAC will clear me up to just perfect. Thanks guys.
Dave
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Oct 20, 2004
#17
  • Oct 20, 2004
  • #17
if not you could try one of those surging idel repair kits.
9
92GreenGT
PEAT
2,085
Big Stone Gap, VA
Oct 20, 2004
#18
  • Oct 20, 2004
  • #18
Whats that?lol
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Oct 20, 2004
#19
  • Oct 20, 2004
  • #19
92GreenGT said:
Whats that?lol
you thought i was joking but its actually a authorized ford part / repair.
http://cgi.ebay.com/ebaymotors/ws/e...tem=7929040813&category=33553&sspagename=WDVW
see the link
9
92GreenGT
PEAT
2,085
Big Stone Gap, VA
Oct 20, 2004
#20
  • Oct 20, 2004
  • #20
see the link
Yeah, I actually thought you were joking but I wasnt sure becuase you are usually pretty serious in your post. Thanks for the link, wonder if that actually works?lol
1 of 2 Next Last
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
M
Progress Thread 1993 Ford Mustang 5.0 convertible stock manual - ODB Codes shows running lean
  • mcalvo
  • Feb 11, 2025
2K
Fox 5.0 Mustang Tech Feb 22, 2025
AeroCoupe
Engine Ran my code reader and
  • Mindseye007
  • Aug 10, 2024
Fox 5.0 Mustang Tech Aug 19, 2024
Mindseye007
P
CEL light on and Can't pull KOER codes.
  • psfoxstang
  • May 7, 2024
Fox 5.0 Mustang Tech Jun 20, 2024
psfoxstang
P
G
Help! 93 Mustang 2.3L A4LD dies at idle
  • goofyfoot53
  • Nov 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
goofyfoot53
G
