So I hear the compression will end up being around 10.4:1...is there anyway to lower that slightly by use of a little thicker headgasket? I don't want to mess with quench area. I would rather not do any 'bowl work' to the heads either.
Also, I'm getting 02 heads (used) and stock PI cams, can I still reuse my valve covers that are on my 98?
What is this I hear about needing a new PI cam bolt? Do I need one?
Can you bolt the heads/cam together or do the heads need to go on, then the cam, then set it up?
Just some brainstorming questions...I will have more...thanks for your time!
