random questions
873Stang
221
riverside
if i remove my quad shocks would that make a diff in driving or anything???
my fuel gauge is kinda wacky what is more likely to be the prob the anti slosh module or the sending unit??? is there a way to test the module???
im grinding shifting into 4th and down shifting to 4th is about 2 months ago i did the clutch, is it trans or quadrant has stock quadrant friend said my clutch is grabing low.
what gears are recommended for street 3.55 or 3.73???
and if i put a intake spacer in would that help mpg????
thx you for your help and thoughts! :SNSign:
Quad shocks help with wheel hop. If you have a good set of Upper and lower rear control arms the quad shocks are not needed.
The sending unit on these things goes. I'm not sure bout testing it but replacing it involves dropping the fuel tank
Odds are your syncro in your tranny is going. Specially if 4th is the only gear it is happening in. How old is your clutch cable? Perhaps it has stretched and needs replacing.
I love my 3.73 gears with a 5 spd. You still turn low rpms in 5th on the highway. They really wake up the car on the street.
I'm not sure bout more fuel economy with a spacer.
I completely agree with what was said above, other than a good set of upper and lower control arms does NOT gaurantee no wheel hop. I've got 3.73 gears, good lower and upper control arms, and unfortunately enjoy a healthy dose of wheel hop with no quad shocks.
