someone told me that you need a torque wrench that goes up to 250 ft lbs for the initial tightening,then you use your inch lb torque wrench on the pinion nut, freewheeling it to fine tune with shims. can anyone running the solid spacer shed some light.Im thinking of switching over from the crush sleeve.plus I just purchased the ratech pinion depth setting tool.
