rattle at 1900 rpm?
aleahey
12
ive got this really odd noise coming from what seems to be the bottom of the car, directly underneath the (A4) gearshift. its like a rattley oddness.
there is also a rattle coming from my timing chain cover, it sounds almost like the chain is hitting it, but i cant seem to figure out why.
any thoughts on either? thanks folks.
if this is a 2.3 u speek of than there is no chain, its a belt, check your belt tentioner, mine was worn out and it sounded like an engine knock, cant help you with the trany noise exept to say get rid of the a4ld. just my 2cents.
ill take a look @ the cat, thanks. i guess it would only make the noise @ a certain rpm because that happens to be the point at which the engine vibrates in a way that moves the thing around, or clanks it against something else.
id get rid of the a4 if i could. i had an 88 with a t5. :-(. i miss it.
