  • SN95 4.6L Mustang Tech
Rattling while accelerating
  • Thread starter Thread starter Deleted member 38176
  • Start date Start date Aug 23, 2011
D
Aug 23, 2011
  • Aug 23, 2011
I've noticed a rattle recently that is originating from, what sounds like, the rear portion of the engine bay to directly under me. It only happens when I accelerate. When I took my foot off the gas it is immediately gone......and immediately returns when I put m foot back on the gas. It sounds like dropping a pebble into an empty soda can and shaking it vigorously.
Im going on about 6 months or so since completely re-doing my exhaust (LT's and mid-pipe). Could something be coming loose (ie. a leak)? Does it sound more like spark knock? I already have leaking valve guides so could this be related to something more serious in that area?
Thanks.
Stumbaugh
903
Russellville, Ar
Aug 23, 2011
  • Aug 23, 2011
If you are being really easy on the car, does it do it? Or does it only do it under hard excelleration?
D
Aug 23, 2011
  • Aug 23, 2011
Both. As soon as the pedal is touched, the rattling commences.
Lugnuts
128
Evans, GA
Aug 23, 2011
  • Aug 23, 2011
What does it sound like from outside the car and where does it sound like it is coming from? with the car running and the hood up, operate the throttle and see if you can discern the location. let us know.
40oz
499
Minneapolis
Aug 23, 2011
  • Aug 23, 2011
It's either an exhaust leak/related issue, or detonation. I'd check the exhaust, but you could try 93 octane or higher to see if it is detonation.
Jhunter
68
  • Aug 23, 2011
If the 93 fixes it or at least helps it you should probably get new plugs and wires.
Stumbaugh
903
Russellville, Ar
Aug 24, 2011
  • Aug 24, 2011
99-04 2v's do not have wires, they are a coil on plug system.
D
Aug 24, 2011
  • Aug 24, 2011
I was just about point that out along with saying that just had my plugs changed.
I payed a little more attention to it today. I only hear it when I am completely off the throttle then hit it aggressively. It doesn't last long but as soon as I get into it hard from a coast, it's pretty loud.
Im thinking it's exhaust related.
Rick 91GT
Mustang Master
95
99
PA
Aug 24, 2011
  • Aug 24, 2011
It sounds like it is tip in spark knock unless you find a clearance issue with the exhaust.
trinity_gt
3,125
81
99
Canada
Aug 24, 2011
#10
  • Aug 24, 2011
  • #10
Nightfire said:
I only hear it when I am completely off the throttle then hit it aggressively. It doesn't last long but as soon as I get into it hard from a coast, it's pretty loud. ...
Agreed. A classic way to describe the sound of detonation to a lay person is to say it sounds like "marbles in a can" which sound a lot like Nightfire's description of it being like "dropping a pebble into an empty soda can and shaking it vigorously."
Bad fuel (incorrect octane for your tune), malfunctioning EGR, too much spark advance (e.g. handheld tuner), low fuel pressure, excessive intake air or coolant temps, a dirty MAF etc can all contribute.
Detonation can damage these engines as the piston crowns above the top ring are very thin brittle and can snap off under the hammering of detonation pressure shockwaves. The sound you're hearing it actually the metal bits of the engine ringing audibly in response to these shockwave hammer blows. I'd avoid sharp tip-ins until you sort it out to reduce the risk of breaking something.
03_TrueBlue_GT
810
41
29
Houston, Tx
Aug 24, 2011
#11
  • Aug 24, 2011
  • #11
I was having Detonation problems with my car about 3 weeks ago similar to what you are describing. I think I just had a bad tank of gas because I ran two tanks of 93 through it and it doesn't do it anymore. Of course I changed the plugs, added seafoam, and used injector cleaner, but you said you just had the plugs changed so that shouldnt be the issue, unless you arent running motorcraft or autolite plugs. It could also be the dang 100* plus weather we have been having out here in Tx.
Jhunter
68
#12
  • Aug 24, 2011
  • #12
My bad, I knew they have the coil system, I'm just used to saying wires. They may need replaced also or rebuilt. I had a spark knock come on in my maxima. I changed the plug and not the coils. It helped but did not fix. I could run 93 and it would not do it, but go back to th e87 and it would. I finally replaced the coils. Problem went away. Car had 150,000 approx miles on it. If your over 100,000 they made need replaced or you may be able to just replace the guts in the boots. That option was available for the maxima.
D
Aug 24, 2011
#13
  • Aug 24, 2011
  • #13
I lowered the oct rating in my tune. I was running a 93 tune with 91 fuel (best we have here). I changed it to the 87 tune and will continue running 91. The sound has decreased drastically but isn't gone completely. Maybe after a few more miles on the tune change will get rid of it. I'll clean my MAF too.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Aug 29, 2011
#14
  • Aug 29, 2011
  • #14
You may want to take it somewhere to get an in person tune since you are having issues that seem to be tune related
D
Sep 16, 2011
#15
  • Sep 16, 2011
  • #15
I don't have that option where I live. It seem to come and go. I have been running the correct octane fuel for my tune.....and it's a BAMA tune (from what I've heard, BAMA is on top of their ****). I am not smelling any exhaust gases whatsoever but I have had some major clearance issues. No matter how carefully/slowly I take speeds bumps and the like, I bang the exhaust occasionally. Oh, I have also cleaned the MAF and the plugs were changed a few months ago.
JoeDaddy
Honey, I need a check for $30k to pay the hooker
760
647
144
SW Michigan
Sep 16, 2011
#16
  • Sep 16, 2011
  • #16
Not sure if you buy your gas at the same station all the time or not, but if you do, you could try switching gas stations. I have notcied where I usually buy my gas (A grocery store gas station, across the street from my house..) that if I go out rompin on it durring the weekend, I'll get detonation under hard acceleration. If I buy my gas somewheres else, it does not do that. Just a thought.
LastCallRacing
Premium Sponsor
Dec 4, 2008
172
San Diego, CA
Sep 16, 2011
#17
  • Sep 16, 2011
  • #17
You can take a datalog and see where your timing is on throttle tip in. Then send it to BAMA and have them adjust the tune so you don't get the spark knock. I'm sure they will adjust your tune for you.
Fabbed4d88
65
Grand Forks ND
Sep 16, 2011
#18
  • Sep 16, 2011
  • #18
I run the same exhaust set-up as you and in my case the exhaust had shifted just enough to rattle ever so slightly against the frame... May want to check that before going to far into unneeded repairs.
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
  • Gulftown980x
  • Jul 29, 2026
squeak93
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
