RCA Pre-outs
RGS0907
429
New Jersey
Sorry for the really basic question, but my searches couldn't answer it.. Exactly what are the the RCA Pre-outs used for? Can I plug an iPod into it or are they used to connect an amplifier pre-amp?
RGS0907 said:
OK, Thanks.
Make sure you check on the actual input voltage that the aux input can accept. Many can only accept 1-2 volts, while a lot of accessories output more than that. This may cause a clipped or distorted signal and you may have to reduce the voltage to get a clean signal. Pioneer is one that comes to mind. Their Aux in adapters can handle no more than 1 volt. Make sure you check your HU and the iPod to make sure the two will work together.
