Re-build
88stangmangt
2,332
Stafford,VA
Im rebuilding my 302 and cant decide between puting new 302 internals in it. Or a 306 kit from dnd this engine is gonna be run at about 6-10 lbs of boost i am buying the vortech next week to get the most expensive thing outa the way right now here is my plan..................(tell me what you think)
302 or 306
gt-40 heads w/1.7 rr's
custom ground blower cam
TRICK FLOWS new box style intake
vortech sc-trim w/anderson powerpipe
maybe 24lb injectors depending on how the dyno run goes.
does this sound like a good combo for 350+ rwhp?
302 or 306
I think you would get the power but you need to get bigger injectors...maybe 36's....???
I plan on doing a combo similar to yours eventually...
David
The Trick Flow box intake..umm NO...COMPLETE OVERKILL for a 306 with Gt40 heads. They would be a massive restriction with that intake and boost.
I concur with above..36lb injectors with boost.
ID go with some tfs or afr head 185 heads
id also recommend the holley systemmax upper and lower
