Really long run on sentence.....
  • Thread starter Thread starter LaserSVT
  • Start date Start date Oct 7, 2007
LaserSVT
3,548
233
Oct 7, 2007
  • Oct 7, 2007
So I was really bored yesterday and decided to play "mechanic" on my Cobra and wanted to pull the passenger side valve cover off so I could fix the ticking noise I hear when the car is cold and ofcourse had no clue what I was getting into much less what the hell I was looking for anyway after I pulled the stru tower brace then the intake pipe then the t-body, plug wires, fuel lines, heater core line and some vacuume lines I was able to get that oversized valve cover off which leads to me not knowing you cant reuse the gasket and will also have to replace the sprak plug hole seals which sucks so $70 and a trip to Napa and that was solved but here I am staring at the cams on my 4.6 wondering what am I looking for I did not see or feel any play on anything and the rollers on all the rockers felt fine no slop or play and the thing that really got me was how clean the inside of the head was, it was all silver with no crud buildup inside so after reassembling a second time, the first time I tried to reuse the gasket it ate up like 5 hours of my Saturday and made me vow to only take her to a mechanic for internal stuff because it still has the noise and I am out $70 oh well at least I did not acomplish anything
And the purpose of this post is I was bored and did not want to use punctuation
CobraRed_96_GT
1,421
UCSD/La Jolla
Oct 7, 2007
  • Oct 7, 2007
Shiroelex
There's nothing worse than aut
728
Westland, MI
Oct 7, 2007
  • Oct 7, 2007
Punctuation is important. Capitalization and punctuation is the difference between, "Helping your uncle jack off a horse" and "Helping your uncle Jack, off a horse"
LaserSVT
3,548
233
Oct 7, 2007
  • Oct 7, 2007
I used a comma in ther somewhere.
screamin gt
5 Year Member
Apr 9, 2007
393
central CT
Oct 8, 2007
  • Oct 8, 2007
I like that, its going to be my new sig
mransr
1,188
36
98
Riverside, SoCal
Oct 8, 2007
  • Oct 8, 2007
for what it's worth...
I had the start-up ticking issue too (185,000 miles what do you expect )...anyway at the last oil change after I got the car up on the ramps, I added a quart of ATF (but didn't overfill it) and ran it for a few minutes...then changed the oil and now the noise is gone
I also changed from Castrol dino-oil to semi-synth, so that may have something to do with it too (and before anybody says anything, I tried Motocraft semi-synth and it made it worse)
LaserSVT
3,548
233
Oct 8, 2007
  • Oct 8, 2007
So did you just drain a quart of oil and add the ATF and then do the oil change?
What kind of Castrol Semi, 10w30 or 5w30?
What does the ATF do?
mransr
1,188
36
98
Riverside, SoCal
Oct 8, 2007
  • Oct 8, 2007
I've got a little leak around the oil filter adaptor so it sorta drains for me
if your oil is topped off, you'll have to drain a little out...
I'm not certain what about the ATF makes it work as a motor flush and why it works so well unsticking lifters, but it does...it's just something that was pretty common back in the 70's when I was getting started messing with cars
I used Castro Syntec Blend 5w-30
LaserSVT
3,548
233
Oct 8, 2007
  • Oct 8, 2007
Tanx!
85ragtop
BTW, I like dudes.
475
123
NC
Oct 8, 2007
#10
  • Oct 8, 2007
  • #10
Yeah look at my ct.
Shiroelex
728
Westland, MI
Oct 9, 2007
#11
  • Oct 9, 2007
  • #11
85ragtop said:
Yeah look at my ct.
That's rough!
Scorcher2005
883
South Carolina
Oct 9, 2007
#12
  • Oct 9, 2007
  • #12
By English language rules, a comma does not belong there.
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
M
  • mnky99
  • Sep 5, 2025
mnky99
M
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Help with window and possible engine
  • StefRena22
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2025
Willybill32
