Hi everyone I have not posted in the classic section before, but I have always gotten some good info on this site in the 5.0 tech area.
A little while ago my grandfather gave me his 70 mach 1. Its a 4 barrel cleveland car, but I think the kind of stuff I am dealing with would be universal.
2 weeks ago I was driving the car around the block and the alternator light came on. I drove the car home, and thinking it was just a bad dummy light, disconnected the negative cable on the battery to keep it from draining. Well the other day I hooked it up to troubleshoot the problem, the regulator started buzzing, then all the power in the car went out. I don't have any lights and the car won't crank.
So I replaced the regulator. Still nothing. All the fuses are good inside.
When I jump the battery positive over to the other side of the metering block, the engine cranks. So I figured maybe the metering solenoid was stuck closed. I replaced that. Still no luck.
The metering block on the 70 is the 4 post style. There is a line on the positive battery side that runs inside the dash from the block. This line then connects to the fuse panel on a stud. There is no power at the stud. I disconnected both sides of the line and tested it to see if it was broken with leads. It is fine.
So I am guessing it is a grounding problem somewhere inside the car?
Is there a master fuse somewhere?
Any other ideas or things I should check?
Thanks for any help.
Chip
Chip
