Rear Axle problem.
make sure when your done that you put new fluid back into the diff.
to put the
c clips in push the axles all the way in then you will see where to put the c clip in( use needle nose pliers. As you get one in pull the axle out then do the other side the put the pinion shaft back in followed by the bolt.
looks as though everything is all set on the passenger side, nothing happend to that side. I will let you guys know how everything goes when im finished but i wont be doing it today as something has come up.
