  • SN95 4.6L Mustang Tech
rear brake install problems
  • Thread starter Thread starter thomas91169
  • Start date Start date Apr 7, 2006
T
thomas91169
I'd donkey punch my sister.
Aug 19, 2005
Modesto, CA
Apr 7, 2006
  • Apr 7, 2006
im going to shorten this for you guys, cause i need answers quick.
1) brakes squealing when not applied, grinding when applied(rears only, fronts are 2 months old)
2)picked up new shoes, installed them to brackets.
3)bought new C-Clamp to press piston back into caliper.
4)piston would not go in farther than where it originally was when the old shoes were on, leaving me to believe calipers are frozen.
5) purchased new calipers and rotors(since rotors were gouged from metal/metal contact
6)installed new calipers, rotors and shoes, no problems there.
7)went to bleed brakes cheater method, runing a vac hose from schrader valve to a bottle with brake fluid.
8) lots of air came out, but brakes still spongy. what did i do wrong?
Dave0803
236
Leonardtown, MD
Apr 7, 2006
  • Apr 7, 2006
do you still have the old calipers? Most likely they weren't bad in the first place. You need a special tool because the pistins need to be turned and pushed in at the same time. The c-clamp won't work back there. As far as the pedal feel...did you check and bleep all the brakes? Are sure your problem isn't in the front?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Apr 7, 2006
  • Apr 7, 2006
The rear caliper pistons screw in, you can borrow a tool for this at AutoZone for a deposit of $40 or buy the tool at Harbor Freight for $40.
As for bleeding the brakes, try installing speed bleeders. This makes it a lot easier for bleeding by yourself.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Apr 7, 2006
  • Apr 7, 2006
well your old calipers were still fine, as others said you screw these calipers in not press them back in.
am I really going to have to embarrass stangnet with a sticky on how to compress the rear calipers.
as far as bleeding the brakes, just get one of those brake bleeder kits from auto zone, it attaches right to the bleeder and all you do is pump the brakes and make sure you top off the fluid.
this works a lot better, either that or do it the old fashioned way. get a friend to pump the brake then while he holds the pedal down you crack the bleeder valve, then AFTER YOU SHUT THE VALVE he lets up on the pedal and do this again until you got a firm pedal.
tomustang
Psychotic Member
3,434
McLean Hospital
Apr 7, 2006
  • Apr 7, 2006
everyone forgets to bleed the master cylinder...
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Apr 7, 2006
  • Apr 7, 2006
Can you bleed a hydroboost?
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Apr 7, 2006
  • Apr 7, 2006
You shouldn't have to touch the two bleeders on the MC. Just bleed normally.
T
thomas91169
Aug 19, 2005
Modesto, CA
Apr 7, 2006
  • Apr 7, 2006
care to elaborate?
also, the chiltons says if air gets into the ABS module, youre screwed(meaning, satan must bleed it their special way), is this true?
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Apr 7, 2006
  • Apr 7, 2006
Don't touch the MC. Those bleeders are there only if you run the system dry.
ALso, there is no reason to bleed the brakes unless it's dirty, or you crack open a brake line which you did.
DOn't worry, not everyone realizes the rear caliper pistons screw in
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Apr 7, 2006
#10
  • Apr 7, 2006
  • #10
Seriously, why would anyone even expect caliper pistons to screw in? Its retarded if you asked me Why did Ford do that? Is it for the emergency brake mechanism or something?
CRZYHRSGT
240
5.7 miles north of THE Ohio State University
Apr 7, 2006
#11
  • Apr 7, 2006
  • #11
You betcha...a lot of manufacturer's rear calipers are the same way b/c of the e-brake being directly built in to the caliper.
T
thomas91169
Aug 19, 2005
Modesto, CA
Apr 7, 2006
#12
  • Apr 7, 2006
  • #12
so umm, any reason why ive been bleeding them for the past 2 hours and while the fronts squirt out when opened, the rears are still a slight drip?
btw, i dont mind about the calipers, the new ones are nice and shiny.
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Apr 7, 2006
#13
  • Apr 7, 2006
  • #13
It's for the e-brake mechanism. It's pretty common with cars that have the e-brake integrated in the caliper.
tomustang
Psychotic Member
3,434
McLean Hospital
Apr 7, 2006
#14
  • Apr 7, 2006
  • #14
I always end up having to do it on the ABS cars, never had to do it on the non-abs GT though
Mike97gt
it doe snot
10,633
Apr 8, 2006
#15
  • Apr 8, 2006
  • #15
not only can you bleed a hydroboost but there is two different bleeds for two entirely different reasons.
if you replace a power steering component you have to bleed the p/s system and with that the hydroboost ( runs off the P/S)
if you open the brake system up you have to bleed the brake fluid.
and why is the screw in calipers retarded. would you rather have that drum in hat design that is prone to failure thats used in the explorer and crown vics and such.
T
thomas91169
Aug 19, 2005
Modesto, CA
Apr 8, 2006
#16
  • Apr 8, 2006
  • #16
ok well taking tomustangs words into consideration, i decided to bleed it from the cylinder.
the man is a genius. first try i had a whole lot of air come out(i was using the bottle-hose method), and bring the pedal up sucked the resevior of half its contents. bled it a few more times and now its back to normal.
tomustang gets 1052 points for nailing it on the head. now i can still make it to paint tomorrow, and hopefully have it back before next weekend.
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Apr 8, 2006
#17
  • Apr 8, 2006
  • #17
I've never had to on an ABS car
My understanding is that you should only touch those if you get air in the MC...which is what sounds like happened to the OP
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
9
Brakes Rear brakes feel stuck after replacing pads and rotors
  • 99stanggtvinx
  • Aug 31, 2024
SN95 4.6L Mustang Tech Sep 1, 2024
nickyb
J
2003 convertible front brakes sticking
  • jamesbanasky
  • Jul 9, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 6, 2025
jamesbanasky
J
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
