rear brakes
stangg01
129
I'm compressing the rear disk brake piston and adjuster into caliper with caliper adjusting tool. When do I stop turning it? The fluid has stoped coming out but the piston still turns. The caliper fits over the new pads now.
The answer seems obvious but I want to be sure.
The bullittarchive site is down. Should I use a dab of high temp grease where the pad sleeves go slide against the caliper holder?
Also, should I use lock tight on the caliper pin retainers bolts?
I just did a brake job on my 02 Sunday. I used the grease where the pads slide on the bracket, but I didn't use locktite on the bolts. I just torqued them to the specs in the Haynes manual. Don't forget to grease the slide pins. I changed pads and rotors all the way around. I had a heck of a time trying to break the caliper bracket bolts loose. I finally had to go buy a propane torch to heat a couple of them with.
Thanks 89lsxsport50
I didn't grease the slide pins. The shop manual didn't say to. It sounds like it should though. I will go back later when it cools down(the weather).
stangg01 said:
Thanks 89lsxsport50
Mine still had grease on them, but I cleaned them off and gooped them up with fresh grease. I also used some permatex disc brake quiet on the back of the pads. It is supposed to help prevent squealing.
