Rear Bumper Question
  • Thread starter Thread starter savegoodautonfg
  • Start date Start date Mar 25, 2007
savegoodautonfg
1,085
  • Mar 25, 2007
I know the bottom of the rear bumper gets held in from these
But the thing is their is a piece that has the holes on it that those retainers go into. That metal piece is held in by Rivets i believe. The piece is loose because the rivets(??) are just worn and old I guess. I think's its rivets im not 100% sure though. My question is can i just use like carriage bolts and a nut or something (if any other ideas other then the bolt and nut please reply with your idea) and if so what size would you guys say to get the carriage bolts in?
Thanks in advance guys....
savegoodautonfg
1,085
  • Mar 26, 2007
bump
madspeed
Colonel Mustard
1,332
204
a van down by the river
Mar 26, 2007
  • Mar 26, 2007
take the whole kit and kaboodle out! Save the weight!!
savegoodautonfg
1,085
  • Mar 26, 2007
Well i dont wanna do that so.. thanks tho..
Lemme know anyone else.
71swing
199
Omaha,NE
Mar 26, 2007
  • Mar 26, 2007
yes, you seem to have the idea. The dont really support the bumper just give stability. So I don't see why your can't drill and insert bolt to tighten up the loose brackets. I think you can access every thing without removing the bumper.
Not a carriage bolt, but just a standard bolt. Carriage bolt are made to be tightened so the head end presses into the materal you are bolting, like wood on a deck. But we are talking metal brackets here.
Bolt size shouldn't matter, something like a 1/2"x1 on each side of the bracket. I would recomend using either lock washers or lock nuts.
4G-KDMP
935
CA
Mar 26, 2007
  • Mar 26, 2007
yes you can use bolts instead of the rivets for the bracket.
savegoodautonfg
1,085
  • Mar 26, 2007
thanks guys.. i hate rivets.
Paint and Body Where does the gas overflow leak tube go with a cobra rear bumper?
  • AnthonyA1234
  • Sep 2, 2025
Fox 5.0 Mustang Tech Sep 5, 2025
AnthonyA1234
P
rear Impact absorbers.
  • Praetorious
  • May 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2026
Praetorious
P
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
Paint and Body What are these rivets in the door for?
  • AnthonyA1234
  • Nov 28, 2023
2K
Fox 5.0 Mustang Tech Nov 28, 2023
91AOD5.0LX
