rear control arm bolts
  • Thread starter Thread starter Shirley
  • Start date Start date Sep 11, 2006
Shirley
112
Phoenix, AZ
Sep 11, 2006
  • Sep 11, 2006
I feel really stupid, knowing that almost everyone on this forum has completed this task. I cannot for the life of me get my rear control arm bolts off, so i can put my new arms on. I soaked them in liquid wrench for about 2 hrs, and for the upper control arm to axle bolt, i cannot get a socket and ratchet on the nut, there is not enough clearance cause the axle housing is in the way. Do I need to buy an 18mm wrench? If anyone can tell me step by step how they did this install I would be much obliged. And i have also heard that gettin the old uca bushings out, and putting the new ones in is alot of fun too. I'm just extremely frustrated. Thanks
M
mercurycapri
211
washington
Sep 11, 2006
  • Sep 11, 2006
I have a air compressor and a air gun and that takes them right off. Its a tight fit but ive done it
Shirley
112
Phoenix, AZ
Sep 11, 2006
  • Sep 11, 2006
i dont have access to air tools. Has anyone done this with hand tools?
Shirley
112
Phoenix, AZ
Sep 11, 2006
  • Sep 11, 2006
wow, i guess i'll just hire a team of midgets to do it for me.
TRWXXA
190
RIGHT BEHIND YOU!!!... Made you look.
Sep 11, 2006
  • Sep 11, 2006
I did it about 18 months ago. I did a rear end housing swap, with nothing but hand tools, all by myself, in my 1-car garage.
I can't remember the exact size wrenches and sockets you need, but I remember it was quite a mix of English and metric. I was able to get a pipe over the wrench I was using and got the bolts to move a fraction of a turn at a time. It took quite a while to get them off.
To get the old UCA bushings out, I drilled away the old rubber material until I was able to hammer the rest out. I have heard the easiest way to get the old bushings out is to torch them out. Whatever you do, don't damage the metal cases around the old bushings -- you need them for the new ones.
Shirley
112
Phoenix, AZ
Sep 12, 2006
  • Sep 12, 2006
thanks man, so i guess a cheater bar is definitely in order
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
C
1965 Mustang Lower Control Arm Question.
  • chopper1876
  • Nov 9, 2024
1965 - 1973 Classic Mustangs -General/Talk- Dec 7, 2024
GOvert
G
Suspension Foxbody ride height change after installing new control arms
  • Mhalc1
  • Jan 3, 2024
10K
Fox 5.0 Mustang Tech May 10, 2024
Mhalc1
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
