  • SN95 4.6L Mustang Tech
rear control arm
  • Thread starter Thread starter mity2
  • Start date Start date Jan 26, 2004
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Jan 26, 2004
  • Jan 26, 2004
I'm sooo new to this solid rear axle thing(i used have nothing but 4 wheel indipendent suspension car in the past), so i'm very much lost on basics.
can someone enlighten me about rear upper & lower control arms? what does it do, and what is good, adjustable, and non-adjustable??
Ottomatic
345
Southern IL
Jan 26, 2004
  • Jan 26, 2004
The upper and lower control arms are in place to limit the front to back, and side to side movement of the rear axle. Here's a diagram:
(Taken from http://www.miracerros.com/mustang/t_suspension.htm)
TacBear
1,243
Jasper, AL
Jan 26, 2004
  • Jan 26, 2004
The old Quadrabind suspension!
nickthegenius
1,631
Elwood, IN
Jan 26, 2004
  • Jan 26, 2004
How easy is it to change the uppers/lowers in your garage on jackstands? I have all the tools needed I believe, but will I have enough clearance is a lift needed?
K
Ken01GTvert
175
Colorado
Jan 26, 2004
  • Jan 26, 2004
I did my 01 in my garage with jack stands. The lower ones were cake to put in. The uppers were a PITA. The toughest part with the uppers were to remove the bushings from the top of the differential. Since I had everything ripped apart anyways I also installed Pro-kit springs and Bilstein shocks. It made a HUGE difference.
mity2
Jul 24, 2003
2,872
StateCollege PA
Jan 27, 2004
  • Jan 27, 2004
thanks for the replays guys! what is the benefit of adjustable one?
stangman
2,690
10
69
in a 3 bed, 2 bath
Jan 27, 2004
  • Jan 27, 2004
if i remember correctly, its to adjust angles in the rear end, so you get better handling at the track. i.e-better launch. if i'm wrong someone will chime in & correct me.
K
Ken01GTvert
175
Colorado
Jan 27, 2004
  • Jan 27, 2004
Yea, i've heard it adjusts the pinion angle which will translate to better times at the track. I don't do the track so I got non-adjustables. I've been noticing that my 3.73s are starting to whine a little and wonder if I had gotten adjustables if I could adjust the angle to reduce the whine. I'm not sure if it would make any difference and I'm not sure how I'd be able to set the adjustables at the optimal angle.
mity2
Jul 24, 2003
2,872
StateCollege PA
Jan 27, 2004
  • Jan 27, 2004
According to mirracelos.com, upgraded control arm with poly bushing id more for drag race. it was talking something about snap oversteer
spree
294
los angeles
Jan 27, 2004
#10
  • Jan 27, 2004
  • #10
i spent 4 hours on trying to do mine before giving up...but that's mainly cuz i don't have all the right tools. I could probably finish it up in an hour or two (including the time needed to get the car on jackstands and remove/reinstall the wheels/tires) if I had the right equipment.
M
Bent Rear Spring Perches
  • Miozu
  • Aug 18, 2025
SN95 4.6L Mustang Tech Sep 8, 2025
PSKSAM2
P
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
C
Suspension Rear suspension help
  • Clark302
  • Aug 17, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
Clark302
C
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
