rear diff going out?
viridionplague
98
so lately ive been hearing a metel on metel rubbing noise at low speeds, i thought it was coming from the pass front wheel but was not sure. nothing is wrong with it at all. today after a long drive at low speeds ive been getting alot of shuttering, thinking it was the rear end i jacked it up, the inside of the rear driver side wheel is covered in fluid but its not the brake lines, there is alot of play in the rear if i rotate one wheel there is alot of play and noise while the other tire will not move. is this a sign the rear end is going out or is it just low on oil and there is a broken seal. ive heard from a mechanic that it will be something like 1200 to replace a seal, this seams like utter bs, tomarrow im topping it off with oil to see if thats the problem. looking forward to feedback thanks
something i forgot to add is that i have noticed alot of oil between the driver side rotor and the dust shield, the axel houseing is coted with oil
The play in the wheel makes me think axle bearing. This probably made the axle seal go out which explains the oil everywhere. It is definitely not a $1200 job. All it requires is pulling the axle, putting a new bearing on, and changing the seal, none of which are that hard.
Definitely get a manual of some sort like mentioned. I got a copy of the factory Ford manual on a cd on ebay for like $8. I like it better than thumbing through a big book and I can just print off a certain page and take it to the car with me if I need to, like a wiring schematic or something. But to pull the axle basically you need to jack up the car and put it on stands, take off the wheel on the side you'll be pulling the axle, unbolt the caliper and tie it out of the way with a zip tie or bungie cord, no need to disconnect the line, drain the diff fluid, take off the cover, there's a little bolt on the diff holding the differential cross shaft in it, take that out, pull the shaft, pull the c-clip off the axle and pull the axle out. You can rip the old seal out with some pliers or slide hammer or something and drive the new seal in with a big socket or seal driver. The bearing will probably have to be pressed off and the new one pressed on, not a big deal for a competent machine shop or chassis/rear end/tranny shop. They should all have the means to do it. Reverse procedure to put it back together. It's recommended to use a new cross shaft bolt every time you remove it, but they're a few bucks at a dealer. Fill it with appropriate fluid and a bottle of friction modifier from Ford. That's basically it, there's a few other little things, but I didn't want to write a book.
The bearing is in the housing behind the seal not on the axle thats why we have "C" clips holding the axle in, unlike 8" or 9" rears that have the bearing pressed on.
When the part of the axle wears from riding on the bearing the axle will wobble a little and a new seal will leak right away. If the axle is too worn it has to be replaced also.
My chiltons guide got me through this pretty well. It's not a hard job at all just kinda smelly. I would replace both axle seals and wheel bearings while I'm there. YOu will def. need to rent or buy a wheel bearing puller and a bearing/seal installer. There cheap simple tools but why buy if you dont do this for a living.
well ive got bad news, just heard back from the shop and basicaly most of the rearend needs replacing, diff, gears, seals and bearings
so the install is going to be 350 if i go with just replacing the parts (LABOR ONLY)
anyone feel like helping me locate parts? or have any sugestions on a good site to order from
i need 3.55 gears for a future turbo
differential. go with an upgraded model or just rebuild what i got?
maybe or maybe not axels?
bearings and seals
350 sounds about right to do the rear. If your planning on a turbo and slicks maybe go with a 31 spline diff. and axles. If its gonna be on street tires you can upgrade to better 28 spline axles when and if you snap these. 3.55's are nice gears. Get ford motorsport ones, they are usually the best quality gears. I believe summit sells full rebuild packages (gears, shims, bearings, seals, diff, etc.) and there prices are very competitive. The diff is up to you, I road race and will be going with a torsen when the time comes, but you may want an eaton or stick with a trac-loc...your gonna have to research whats best for you as far as that goes. Hope this helps.
