rear diff oil
Night Shifter
Well-Known Member
Dec 24, 2005
1,710
27
59
Daytona
i finally bought a set of 3.73 for my car but i want to use the best gear lube. any suggestions? I'm looking at royal purple max gear 75w90. I'm a noob to the rear diff so how many bottles do i need?does it matter the year car you have for gear lube?
I run Mobil 1 75/140 without friction modifier. Need 3 quarts. Won't quite use all of it though.
Prior to 2001 Ford spec'd 80W-90 gear oil, mid 2001 they started specifying 75W-140 synth. Should be a tag on the diff if there is any confusion.
Use 4 ounces of friction modifier regardless unless it is already "in there" like with Royal Purple.
