rear disc brakes
ok is this what i need to switch to disk in the rear?
a 4 lug rear disc brake kit off of a 1988 Ford Thunderbird Turbo Coupe. This kit will also fit Ford Mustang GTs and Cobra's. The kit includes axles, calipers, caliper mounting brackets, pads, brake lines, flat mounting brackets, anti-moan brackets, and mounting bolts.
does that look right?
Something I think you should think about is what the future plans are for the car, upgrading to a larger spline axle and better carrier is a must if you plan to make a lot of power or race a lot.....
a 4 lug rear disc brake kit off of a 1988 Ford Thunderbird Turbo Coupe. This kit will also fit Ford Mustang GTs and Cobra's. The kit includes axles, calipers, caliper mounting brackets, pads, brake lines, flat mounting brackets, anti-moan brackets, and mounting bolts. Does that look right?
See http://www.svo73mm.cjb.net/ for everything you need to know... Matt90GT's brake site.
Some of the items missing are the proportioniong valve, new master cylinder and ebrake cables. Visit the site above and you will find a detailed description of what to do and how to do it.
