  • 1994 - 1995 Specific Tech
Rear end clunks/noises...
  • Thread starter Thread starter click
  • Start date Start date Jul 14, 2005
C
click
142
  • Jul 14, 2005
I had a previous problem with my front end clunking over bumps and it was my sway bar ends links. So i replaced them... Now my rear end makes noises. When i'm braking, comming to a stop, taking off from a stop, or a hard turn. Usually the sounds are like 3 clicks. click click click. It weird cause sometimes it sounds like it comes from different spots. Once in a while i think its directly under me or else its towards the back.
Whats the first place to check for this problem?
94-302-vert
1,947
NE CT
Jul 14, 2005
  • Jul 14, 2005
What are you rmods?
Things that can make noises are the 4-link bars, a bad gear install, a wiped rear end bearing, driveshaft u-joints, brakes sticking, etc.
I had a similar problem and it was tied to a wiped pinion bearing and the driveshaft...
9
94menace
  • Jul 14, 2005
my stang made the same type of noise and the problem was the bushings. try to see if they have gaps in them or if they are broken.
94TURBO5 O
2,509
VA
Jul 15, 2005
  • Jul 15, 2005
Check your control arm bushings upper and lower ones for worn bushings.
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Y
Engine 1994 Ford Mustang Gt Rod Knock/Stuck Lifter
  • yaboity
  • Jun 7, 2025
1994 - 1995 Specific Tech Jun 8, 2025
AeroCoupe
Drive Shaft/Rear Diff Issue on 2014 GT
  • DudeStang
  • Jun 16, 2025
  • 2010 - 2014 Specific Tech
2K
2010 - 2014 Specific Tech Jan 21, 2026
gkomo
