I just changed out the third member on my 8" granada rear and filled it up with gear lube. WHat is the capacity of the third member gear oil? I put in a quart and it has not spilled out the drain hole yet. Is the 1 quart enough or do I need to add more until it overflows?
Filling mine was a bear as there was no angle to get to the rear fill hole with the gas tank and exhaust in the way. How do you guys do it? I used a 1/4" flexible hose and attached to the gear hole nosel and fed it through the filler hole and sqeezed. Took 1/2 hour!!!! My hands were sore from 1/2 of continuous squeezing to force the oil through.
