Rear End Gear
  • Thread starter Thread starter oakeydoke
  • Start date Start date Aug 20, 2004
O
oakeydoke
27
  • Aug 20, 2004
Is there anyway i candetermine the gear in my car I just bought it and the guy said he thought it was stock, but it sure turns up awfully fast to be stock
Thanks in Advance!!!
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Aug 20, 2004
  • Aug 20, 2004
Jack the back of the car up (both rear wheels). Place a mark on the driveshaft and a mark on the tire. With the car in neutral, rotate the tire exactly one time and carefully note how many times the driveshaft turns. If it's about 2 and 3/4 turns - that's a 2.73 gear; if it's a little over 3 that's a 3.08; if it's about 3 and 1/4 that's 3.27; if it's about 3 and a half, that's 3.55; if it's about 3 and 3/4 turns, that's 3.73's; if it's a little over 4 that's 4.10. Some will tell you to look for tags on the axle or to decode the VIN - that only works if you know the complete history of the car and you know the rear end has never been swapped and the gears have never been replaced.
88_GT_5_oh
Sportin' a turbo 5.0 in Canadistan
Jul 4, 2004
WPG/MB/CA
Aug 20, 2004
  • Aug 20, 2004
wow i always thought the only way to be sure is to open it up and count teeth.... but that is way easier, wish i woulda known that when i was shopping for gears.. i just assumed they were 3.27's.
super302
I'd do anything for free Bapples
May 29, 2004
2,878
Davenport, IA
Aug 20, 2004
  • Aug 20, 2004
do what michael yount said....i think if you go in 4th gear at 70mph, just divide the rpm's by 1000??
Correct me if i'm wrong, heard this a while ago.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Aug 20, 2004
  • Aug 20, 2004
"i think if you go in 4th gear at 70mph, just divide the rpm's by 1000??"
You could come up with an algorithm like this, but it would vary with tire size -- so it won't work on every car/every tire size. Counting turns is the easiest/surest.
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
K
Drivetrain '87 5.0 Installing New Ring Gear and Pinion - Pattern Questions
  • karhoot
  • Apr 23, 2026
Fox 5.0 Mustang Tech May 9, 2026
Mindseye007
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Drivetrain 5th Gear Ratio
  • PonyGTrider
  • Dec 8, 2025
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
