i called my mechanic and took it to him today and we put it on the lift and first thing i looked at was the driveshaft where it is connected to the rear end well all of the bolts where only in there hand tight i loosened them up with my fingers. so we took all of them out and put lock tight on them. well i drove out of there and it was fine. until i got a little farther (it was dark by then) i did a litttle burn out and it started making that same noise so 2marrow i guess i will have to crawl under there and see if the have loosened up again hopefully that is the same problem. do you know if they are suppose to have a lock washer on them because mine doesnt and was wondering if they are suppose to? and if so do you think it would be a good idea to put lock washers on the bolts? thanks for all your help
