Hey guys, I get a rear end noise going over bumps or holes, but is most easily replicated over speed bumps. It's a high pitched metallic clunk. More like a "pliiiing" almost like tapping the exhaust pipe with a wrench. I've checked the clearance of the exhaust over the rear end/ under the body and it looks ok. I've also double checked the bolts for my control arms and sway bar. I just can't figure it out. If you could imagine a tire rolling over a speed bump, it makes the noise on the initial hit of the bump and then again on the downward slope of the bump (if that makes sense/helps). I was just wondering if you guys could help me brain storm. Thanks.
