Rear end options
With an automatic behind a turbo 4, the 8" would almost be overkill for strength. I used to run my 351W+C4 with a 2.79 8" and broke 3 transmissions without hurting the rear end at all.
Stick shift is a different story, but since you're running a boosted 4, you still wouldn't be that hard on it even when abusing it. I've broken an 8" with a 302 + T5, and broken a 9" with the 351W + Tremec. Prior to putting a T5 behind my 302, I broke 2 RAD 4spds.
Nice to see that another Turbo II will be on the road, with the same HP goals I have for mine. Too bad mine has been sitting in the garage for 3 years now waiting on me come up with an intercooler, intercooler plumbing, exhaust, wideband O2, and bigger injectors.
Recently purchased a 1975 Mustang II Ghia. The rear end is growling at low speed. While I am having that looked at, I was thinking about having the rear end turned into a posi rear end. Is there a kit that can be purchased to convert the 8" C2 that came stock? If so, where do I find one that is reasonably priced?
Any help much appreciated.
Terry
To Jeff and All,
I am asking for clarification of what "Summit Racing powertrax unit." means.
I use to work on cars when I was a teenager, but have not until now that the kids are leaving home and I can finally afford to play around with older cars. Therefore, I am a bit rusty.
I am trying to find out what my options are as far as using the existing stock rear end in my '75 Ghia and turning it into a posi rear end if possible.
The Codes I listed before are off of the tag on the rear end.
I looked them up and the first line means:
3.00:1 ratio
8" Gear diameter
C2 differential type
It is a removable carrier type rear end.
Hope this helps to clarify things.
Terry
To Jeff and All,
I am trying to get clarification by what Jeff meant by "Summit Racing powertrax unit."
I have not really worked on cars since I was a teenager and now that my kids are FINALLY leaving home, I can afford $$ and time to work on an older car. Therefore, I am a bit rusty (me, not the car!).
What I am trying to do is to use my existing rear end in the '75 Ghia and turn it into a posi rear end if possible. I am just wondering what my options are.
Terry
To Jeff and All,
Link to Powertrax web site.
There are numerous options for the Ford 8", not as many as the 9" but still .....
I suggest starting a new thread asking this question. I think you'll get more action/responses.
Mark,
When I do that it tells me that I cannot post new threads. On the bottom of the page that I am looking at now, it says I can post new threads, but when I went to the page that you directed me to, it would not let me post a new thread and on the bottom of that page it says that I cannot post new threads. Damn it, I am just trying to get an answer to my question!
Terry
You obviously haven't driven a well-modified 2.3. A week after getting doing a ported head/cam/turbo swap on my SVO, my V8-spec T5 started grinding going into 3rd and doesn't like being speed shifted into 2nd. Modded 2.3 turbos make just as much torque as a V8, albeit only when under boost. Powershifting will be out of the question with a RAD-4.
