  • SN95 4.6L Mustang Tech
Rear End Problem???
  • Thread starter Thread starter 98bluevert
  • Start date Start date Mar 26, 2008
98bluevert
130
Mattoon, IL
Mar 26, 2008
  • Mar 26, 2008
What are the chances of of a ring bolt shearing off or backing out. took it into the shop today and they said one bolt was completely missing(ground up probably) 2 where out just floating around and a couple others where backing out.
Its been 4 years but only 15,500 miles since my 4.10 was replaced.
also while its apart should i have the trac. lok rebuilt. the tech said he has never done one before and i don't want to open another can of worms if its not worth it. i had no problem with it before but just wondering about preventative maintence.
Car has 69,000 miles on it.
Tripoli
208
Dallas, TX
Mar 26, 2008
  • Mar 26, 2008
I had a couple bolts back out on my 4.10s once. Still not sure why, but it never caused a problem. With 69,000 miles, I would consider rebuilding or upgrading the diff, but I would make sure someone experienced does it. Those things can be finicky.
98bluevert
130
Mattoon, IL
Mar 26, 2008
  • Mar 26, 2008
Found out they didn't use locktite on mine
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
