Rear End Problems
  • Thread starter Thread starter marine_2003
  • Start date Start date Aug 17, 2005
marine_2003
427
Lake County, FL
Aug 17, 2005
  • Aug 17, 2005
I have been having for some time problems with my rearend. It slides out from underneath me while driving down the road, it makes a metal grinding noise when i make a sharp turn, and it makes noise everytime i put it into gear. I jacked up the rearend, and had no problem with the driver side, but when the car went up the bottom of the passenger side tire fell inward and the tire has some play in it, i tried tightening up the lug nut just to be sure, and it didnt help. Are my rear wheel bearings bad? if so hopefully thats all thats wrong.
Thank You
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Aug 17, 2005
  • Aug 17, 2005
Has the car been driven hard? Having the rear end move around like that is a good indication that your torque boxes are torn. I would jack the car up and look closely where the lower control arms attach near the body.
To check if your axles are at fault: (broken C clip) they should just slide right out with the tires off the ground.
marine_2003
427
Lake County, FL
Aug 17, 2005
  • Aug 17, 2005
Then car is driven hard (street raced) from time to time, i havent checked where the lower control arms attach near the body yet, will do tomorrow, but with the car jacked up, if i grab the bottom of the passenger side tire and shake it it moves, it wont come out that what makes me think that the bearings in the rear axles are bad.
Resolved 2015 ecoboost pp bumpsteer issue
  • matthewt
  • Aug 1, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Aug 3, 2026
fasterthangas
F
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
